tranny to carb connection? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-11-2011, 09:52 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
The shop that worked on my Goat ran the line I had from the tranny to a vaccum conn on the carb, to the rear p side bolt on the carb?
it runs ok.
but im confused..............The GTO Wizzard told me the tranny needs"full vaccum"
ideas?
thanks as always
Topkat is offline
post #2 of 4 (permalink) Old 09-11-2011, 10:15 AM
TK, That is full vacuum, as it is beneath the throttle plates......Eric
Eric Animal is offline
post #3 of 4 (permalink) Old 09-11-2011, 11:48 AM
Quoted: 102 Post(s)
TK, Eric is right. The original vacuum source for the trans line is a metal pipe pressed into the carb, but I understand you have a non-original carb. No worries, manifold vacuum is manifold vacuum. Ported vacuum is above the throttle plates, manifold below. when the throttle is stabbed, the throttle plates open, and manifold vacuum drops to near zero. The transmission modulator senses this vacuum change, and in conjunction with the governor (which senses engine speed) it "tells" the trans when to shift.
post #4 of 4 (permalink) Old 09-11-2011, 01:35 PM Thread Starter
Topkat's Avatar
I'll be dammed......that there carb mounting stud IS HOLLOW!!!
I shoved a piece of stiff wire 5'' into it.
you 2 are the bomb!!
take the rest of the war off!!!
TK
Topkat is offline
Vacuum advance connection Bayoupappy 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 10-11-2009 08:25 AM
connection pipes socal gto Intake and Exhaust Discussions 8 04-27-2006 09:54 PM
pontiac tranny to chevy tranny wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-27-2006 08:23 AM
Spoiler connection Seattle GTO Service, Maintenance and Technical Discussion 3 07-07-2005 06:27 AM
