tri power - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-23-2015, 12:25 PM Thread Starter
tri power
Hey all, just picked up 3 carbs. Would like some info. Can't seem to match numbers from the center carb. Can someone tell me what this carb is so i can get a rebuild kit. Thanks
krallstar is offline
post #2 of 4 (permalink) Old 01-23-2015, 01:32 PM
Roger that's Avatar
It is a Rochester 2GC series carb with electric choke. The casting number printed on the bowl location tells me it is a 1968 and later carb (well after the tri-power era ended). Most 2GC rebuild kits will work for various years and applications.
Roger that is offline
post #3 of 4 (permalink) Old 01-23-2015, 05:38 PM Thread Starter
Found some info, seems this carb is a mercruiser carb. They all have the wide base. Was told they came off a 389. Planning to use them on my 400.
post #4 of 4 (permalink) Old 01-23-2015, 08:14 PM
Roger that's Avatar
Mercury Marine did use the Rochester carb on some of their engines. Rochester stopped production and then Mercury made its own version of the Rochester called a Mercarb. The Mercarb had two different styles of accelerator pumps.
Tri Power 65gto 1964-1974 Tempest, Lemans & GTO General Discussion 3 10-29-2013 03:11 PM
Power Brakes with Tri Power timmyg 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 08-21-2013 03:10 PM
65 tri-power orelog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 09-22-2012 08:20 AM
'65 Tri-Power TheGreatBuzz 1964-1974 Tempest, Lemans & GTO General Discussion 4 12-01-2009 03:53 PM
Tri-Power GTO JUDGE 1964-1974 Tempest, Lemans & GTO General Discussion 5 03-01-2009 04:04 PM
