Tri power carbs - Pontiac GTO Forum
post #1 of 6 (permalink) Old 09-23-2014, 11:04 AM Thread Starter
Tri power carbs
I have an intake for a 66 GTO tri power.Does anyone know of aftermarket carbs that will work,with adapters perhaps? Holley 2 barrels or something?Or a source for stock replacements?Originality isn't a must,as it's going in a Ventura,not a GTO.If I still had a GTO I'd go the original carbs regardless of cost,but since it's a mix match I'll use whatever I can so long as they work.Thanks......
jaloi is offline
post #2 of 6 (permalink) Old 09-23-2014, 03:58 PM
Roger that's Avatar
There are 2 companies that have done some strange Pontiac tri-pwr things. One is called the Barry Grant Sixshooter (1st pic). Manifold does not look stock. Not sure of the carbs either.
The other company is TMP Carbs which uses the 1966 reproduction manifold but uses other componets to allow Holley carbs to work (2nd Pic).
TMP has a complete unit for sale on ebay: Pontiac Tri Power Three Dueces Six Pack Set Up | eBay
ID:	46274   Click image for larger version
Roger that is offline
post #3 of 6 (permalink) Old 09-23-2014, 04:25 PM
Roger that's Avatar
post #4 of 6 (permalink) Old 09-23-2014, 04:52 PM
Quoted: 368 Post(s)
You can pick up 3 Rochester 2bbl carbs (make sure they have the larger throttle bores to match your intake and not the smaller carbs -get a gasket for sizing) at most any swap meet or ebay for cheap. I would not pay anymore than $20-$30 tops in good, complete, and working order. Then you can purchase the end carb bases which eliminates the idle mixture screws -many places sell these new. Then get 3 rebuild kits, your linkage, lines, air cleaners, etc..
It should be very reasonable to do it this way as opposed to purchasing either the correct carbs or factory set-up. Forget the Holley carb set-up unless you have deep pockets.
post #5 of 6 (permalink) Old 09-23-2014, 05:17 PM
Quoted: 103 Post(s)
True tripower end carbs also have no choke or provision for one. So, sourcing regular carbs, the chokes would need to be removed, along with the base plate change.
post #6 of 6 (permalink) Old 09-30-2014, 08:12 AM
allpawl66's Avatar
Can supply you with 3 non original ready to use carbs. for a very fair price .
allpawl66 is offline
Tri Power Carbs restoration xconcepts 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 15 07-05-2014 12:35 PM
Power Brakes with Tri Power timmyg 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 08-21-2013 03:10 PM
66 GTO Tri-power Manifold w/ carbs vrusso1096 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 11-17-2012 02:47 PM
66 GTO Tri-power Manifold w/ carbs vrusso1096 1964-1974 Tempest, Lemans & GTO General Discussion 0 11-17-2012 01:04 AM
