Tri-power choke tubes - Pontiac GTO Forum
post #1 of 2 (permalink) Old 08-31-2014, 09:23 PM Thread Starter
I am trying to remove the 2choke tubes that connect the center carburetor
choke to the intake manifold. One has a crack just above the manifold. I have tried soaking the area with penetrating oil but they won't move. I want to replace them with new tubes, but do not want to break them off in the manifold tubes. Can anyone give me any ideas how to get them out without damage. The manifold is a 1965 model.
Thank you
Steve
trimfixer is offline
post #2 of 2 (permalink) Old 08-31-2014, 09:37 PM
Roger that's Avatar
You could use a slightly bigger drill bit than the tubes, spinning it up the bit shank.
Roger that is offline
tri power tvalenti03 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 02-19-2014 04:23 PM
Tri Power 65gto 1964-1974 Tempest, Lemans & GTO General Discussion 3 10-29-2013 03:11 PM
Power Brakes with Tri Power timmyg 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 08-21-2013 03:10 PM
65 tri-power orelog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 09-22-2012 08:20 AM
'65 Tri-Power TheGreatBuzz 1964-1974 Tempest, Lemans & GTO General Discussion 4 12-01-2009 03:53 PM
