Trivia Question about Pontiac Hood Tachometers - Pontiac GTO Forum
post #1 of 14 (permalink) Old 08-05-2014, 03:32 PM Thread Starter
Grant1969's Avatar
What was the highest RPM Redline every put in a factory Pontiac hood tachometer and what engine was it used for?
Grant1969 is offline
post #2 of 14 (permalink) Old 08-05-2014, 03:40 PM
Without looking it up, I believe it is 5500 rpm for the OHC Sprint engine in a firebird....
Nightshade 68 HO is offline
post #3 of 14 (permalink) Old 08-05-2014, 03:58 PM
And the Firebird was Verdoro Green!
Matthew is offline
post #4 of 14 (permalink) Old 08-05-2014, 04:02 PM Thread Starter
Grant1969's Avatar
You were correct about the engine, it was the Sprint OHC 6 banger. It was installed in A-body (Tempests & LeMans) and F-body ( Firebirds). However your RPM guess was incorrect.
post #5 of 14 (permalink) Old 08-05-2014, 04:50 PM
Quoted: 390 Post(s)
1969 OHC Sprint 6-cyl having 230HP @ 5,400 RPM's.
5,400 RPM's is my final offer.
post #6 of 14 (permalink) Old 08-05-2014, 08:26 PM
Roger that's Avatar
6500 rpms
Roger that is offline
post #7 of 14 (permalink) Old 08-06-2014, 06:56 AM
Pro/cons of hood tach? I think they look cool, but hate the idea of cutting a hole in my roof. Also what about it bad weather do they go bad easy?
srea76 is offline
post #8 of 14 (permalink) Old 08-06-2014, 08:04 AM Thread Starter
Grant1969's Avatar
6,500 is the correct answer. It was for the 1967 OHC Sprint 6-cyl having 230CI and 215HP. A HO 10.5 compression motor that had the highest HP to CI ratio of any Pontiac engine produced during the muscle car era. Pontiac realized very quickly that the redline was set too high and started using 5,500 redlines after only a few months of production. Pontiac also decided the tachometers were too large and reduced the size both length and height after only a few months of production as well.
post #9 of 14 (permalink) Old 08-06-2014, 08:06 AM Thread Starter
Grant1969's Avatar
Note: A hood tach should be mounted on the hood so you can see it from the driver's seat. I do not advise mounting it on the roof.
post #10 of 14 (permalink) Old 08-06-2014, 09:53 AM
I guessed the correct replacement, I was not aware of the original 6500! Good to learn...
The Hood tach is best looking in Nightshade Green....and can run extra rpms without engine damage....
Ordering Hood tachometers in 1967 Grant1969 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 08-15-2014 12:02 AM
Car trivia pjw1967 The Lounge 1 06-05-2014 11:49 AM
Pontiac hood latches norwood 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 11-16-2008 11:24 AM
04-06 GTO trivia game 06brazengto 2004-2006 GTO General Discussion 18 01-03-2008 10:31 AM
A little muffler trivia LYNMUP Intake and Exhaust Discussions 2 05-30-2006 05:10 AM
