turn signals - Pontiac GTO Forum
post #1 of 15 (permalink) Old 07-11-2011, 07:42 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
turn signals
I got my flashers all working.
Finally got the lamps for my front bezels in.
BUT my [email protected]#$%^&*(&^ turn signals still dont work.
a few months back I thought none would work unless the fronts were hooked up too. load and all that........
dagnabbit...............
I tried 2 different flasher s and they still dont flash.
What else could this be
thanks as always
Topkat is offline
post #2 of 15 (permalink) Old 07-11-2011, 07:59 PM
Did you change both flashers or just the one in the fuse panel.......?? Do they light up steady, or not at all?
Eric Animal is offline
post #3 of 15 (permalink) Old 07-11-2011, 09:48 PM
crustysack's Avatar
you of course cleaned out the bulb socket with scotchbrite or steel wool and used some dielectric grease when installing the new bulbs????
crustysack is offline
post #4 of 15 (permalink) Old 07-12-2011, 06:37 AM Thread Starter
Topkat's Avatar
The flasher in the fuse panel is for the 4 way flashers.
I beleive there is only the one for the turn signals (located under the das by ones right knee)
all the lights are on and steady.
Topkat is offline
post #5 of 15 (permalink) Old 07-12-2011, 06:55 AM
OK, probable cause.....bad flasher. OR an improper wire some where..like one lead crossed into a steady on circuit (headlights , or parking lights) Disconnect 1 wire from the flasher under the dash near your left knee. Turn the signal switch to left and check, then right and check.........then remove the flasher from the fuse panel and repeat........are you using LED bulbs?.....then report findings to us. Eric
post #6 of 15 (permalink) Old 07-12-2011, 06:57 AM
....grounds and "hot' connections are VERY important!!!! e
post #7 of 15 (permalink) Old 07-12-2011, 07:57 AM Thread Starter
Topkat's Avatar
The grounds on my light bezels are somewhat of a mystery.
they are each a white wire with a round lug.
jumpered together and put to the batterys neg, or left totally unconected the 4 ways work.........lol
The blinkers did work if i toggle the turn signal lever...............
one thing.............i did find and open filiment on one of the 4 tail light bulbs.....
stay tuned and thanks
TK
Topkat is offline
post #8 of 15 (permalink) Old 07-12-2011, 03:41 PM
DukeB-120th's Avatar
TK
From my (limited experience), it sounds like that open filament might be to blame. Any time you have burned out bulbs, weird stuff tends to happen. make sure you don't have any more busted bulbs.
KICK THE TIRES & LIGHT THE FIRES
Dreamin of Montero Red & Parchment White '66;
2004 LS1/T-56; LMII, Skipshift del, GMM Ripshift, K&N CAI, TC AutoOff, AVIC-7000NEX
1992 Dodge Dakota LE; 5.2L Magnum
2006 Kawasaki EX250
DukeB-120th is offline
post #9 of 15 (permalink) Old 07-12-2011, 05:46 PM
Burnt filament!
post #10 of 15 (permalink) Old 07-12-2011, 06:37 PM Thread Starter
Topkat's Avatar
new bulb didnt make them flash..............but now, when I remove the ground from the light fixtures............the lites in front go out and BOTH arrows on the dash are on....
so that has changed.
puzzling!!!!
Topkat is offline
turn signals Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 8 05-14-2011 03:42 PM
'68 turn signals 68greengoat 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-05-2011 09:18 PM
having problems with turn signals skapegoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 10-21-2010 05:08 PM
Turn Signals not working? ChargerCop 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 04-11-2009 05:18 PM
help with turn signals HoldenGTO Service, Maintenance and Technical Discussion 4 01-19-2006 06:15 PM
