Turn signals - Pontiac GTO Forum
post #1 of 9 (permalink) Old 08-01-2012, 06:42 PM Thread Starter
joesweeting's Avatar
Turn signals
My turn signals do not work, when I step on the brakes both turn signal lights light up on my dash and on the front of the car (I can see the turn signals in the reflection of the vehicle in front of me) Iím assuming it is a relay. Brake lights and tail lights work fine. Any previous experience with this issue would be greatly appreciated.
joesweeting is offline
post #2 of 9 (permalink) Old 08-01-2012, 08:19 PM
no relay involved. check your wiring diagram. it is the turn signal switch. not grounds or connector since brake and tail lights work.
pontiac is offline
post #3 of 9 (permalink) Old 08-01-2012, 09:07 PM Thread Starter
Thanks for the information. My tech manual is in the garage I use to work on my car. I will look into switch, I believe this should be the correct one(using google)
http://m.autopartswarehouse.com/deta...QACD6251D.html
Thanks,
Sent from my DROIDX using AutoGuide.Com Free App
post #4 of 9 (permalink) Old 08-02-2012, 04:19 PM
Quoted: 103 Post(s)
Also, check the connections at the large horseshoe plug under the steering column. They can back out and get loose, and give you issues as well. BTDT.....
post #5 of 9 (permalink) Old 08-02-2012, 05:57 PM Thread Starter
Will do, thanks for the information
post #6 of 9 (permalink) Old 08-03-2012, 02:38 PM
Also, check the ground wires on the taillight assemblies themselves. I just had to replace them yesterday because mine weren't working. The ground wires were old and had a bad connection.
etewald is offline
post #7 of 9 (permalink) Old 08-04-2012, 10:44 AM
Check ALL the bulbs for blow outs, then check BOTH flasher units....FIRST check the fuses......................go from there.
Eric Animal is offline
post #8 of 9 (permalink) Old 08-10-2012, 07:47 PM Thread Starter
Replaced all bulbs, fuses and flasher fuse. Using a test light , I have power to my turn signal switch but not after. Ordered new switch will be in next week. Will keep informed, thanks for all the input
post #9 of 9 (permalink) Old 09-22-2012, 07:46 PM Thread Starter
Replaced switch, turn signals work!! sorta they won't turn off after turn. Also installed aftermarket grant steering wheel. Will investigate when steering wheel removal kit arrives, ETA?? Been waiting over 2 months, called year one and was told it will be at least another 2 months. Thanks for everyones input
Sent from my ADR6425LVW using AutoGuide.Com Free App
turn signals Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 14 07-13-2011 08:21 AM
turn signals Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 8 05-14-2011 03:42 PM
'68 turn signals 68greengoat 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-05-2011 09:18 PM
front turn signals Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 04-25-2011 07:28 PM
help with turn signals HoldenGTO Service, Maintenance and Technical Discussion 4 01-19-2006 06:15 PM
