Unexpected water help. - Pontiac GTO Forum
post #1 of 6 (permalink) Old 06-12-2019, 06:25 AM Thread Starter
Hello, looking for advice on how to track unexpected water on front passenger floor. Have a 72 Lemans with air, ran the air when i brought it home, washed it a few days later and noticed the carpet was wet. Ideas on how to track this down?? Thanks
ID:	119521   Click image for larger version
Ghurst is offline
post #2 of 6 (permalink) Old 06-12-2019, 06:29 AM
deanhickey's Avatar
Quoted: 38 Post(s)
For me the prime suspects would be heater core or leaking around the windshield . The later is the easiest to check, sit in the passenger side with the door closed and have someone spray one area at a time and check for water, If this yield no results run the A/C for a half hour or so and do the same. Good luck.
deanhickey is online now
post #3 of 6 (permalink) Old 06-12-2019, 08:35 AM
joelau27's Avatar
This sounds like your evap. drain could be clogged. If it is it will back up and drain out the bottom of the heater box. Just something to check.
joelau27 is online now
post #4 of 6 (permalink) Old 06-12-2019, 11:14 AM Thread Starter
Thanks, how would one find the drain?
Ghurst is offline
post #5 of 6 (permalink) Old 06-12-2019, 11:20 AM
joelau27's Avatar
The drain is located under the evap case in the engine compartment. You can reach your hand under the case to feel it, or from underneath look past the oil filter housing. On my '69 GTO it looks like a small rubber piece with a spring clamp holding it on the evap. housing. Good luck.
post #6 of 6 (permalink) Old 06-12-2019, 11:26 AM
joelau27's Avatar
Look on Ames catalog pg. 261 item #P134DL . This is what you are looking for.
