Up late drinking and thinking - Pontiac GTO Forum
post #1 of 7 (permalink) Old 08-27-2009, 01:16 AM Thread Starter
Cpldavis37's Avatar
I just got my 1970 Lemans started after 10 plus years of sitting (thanks for the help). I drove it around the block and the engine feels strong, but I was reading about a 383 stroker kit. Has anyone tried this product. I know not many of you have the pontiac 350, but any advise or thoughts would be helpful. Also when I drove it around the block I was unable to shift. I have a Saginaw 4 spd. Could this be the synchro or could it be a linkage problem? It shifts ok when the car is stopped and not turned on. Should get the transmission rebuilt when I have the engine out anyways.
Cpldavis37 is offline
post #2 of 7 (permalink) Old 08-27-2009, 09:10 AM
Quoted: 98 Post(s)
The only 383 stroker kits I know of are for Chevrolets. As for your shifting, I would check the external linkage first. If the synchros are worn, it will shift, but it will grind a bit unless you double-clutch it or float the gears.
post #3 of 7 (permalink) Old 08-27-2009, 09:10 PM
67 Basket Case Restorer
Too Many Projects's Avatar
Could be the clutch is hanging up a bit on rust from sitting that long and not releasing the input to let you shift.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #4 of 7 (permalink) Old 08-27-2009, 10:30 PM Thread Starter
Cpldavis37's Avatar
I found these kits @ Pacific Performance Racing - Tomahawk Performance Parts Like I said though I have no idea if they are of any quality. Thanks for the transmission advise
post #5 of 7 (permalink) Old 08-29-2009, 07:14 AM
scrapmaster's Avatar
A lot of those parts are made in China. Had some guys install the manifold and had problems. Stay away from Tomahawk Stroker kit. There is a place in Kentucky or Tenn. I will see if I can find it.
scrapmaster is offline
post #6 of 7 (permalink) Old 08-29-2009, 10:10 AM
If you want more cu in, probably better and cheaper to find a 400 and rebuild it.
67gto455 is offline
post #7 of 7 (permalink) Old 08-30-2009, 08:10 PM
harp's Avatar
in the late 70's i drove a 69 lemans with a 350, i spent thousands trying to get it to go faster, and could never touch a stock gto!!!! thats why i bought a 69 gto 3 months ago! your 350 would need lots of rebuild work to get to where a stock 400/350hp would be,so maybe you swap?
harp is offline
