Upgrading headlights in a 69' - Pontiac GTO Forum
post #1 of 19 (permalink) Old 03-23-2011, 07:50 AM Thread Starter
Hey there, hy headlights are really weak and whenever I drive at night they barely go far enough to see well. Are there any HID kits or any brighter bulbs I could put in? I've searched for HIDs and couldn't really find anything.
- Judson
Pontiac Z is offline
post #2 of 19 (permalink) Old 03-23-2011, 08:36 AM
Hot_Rod's Avatar
I imagine you can just look up the bulb type and buy an HID kit with that kind of bulb on ebay. (if the 40+ year old type is still common lol)
Not sure how purists will think about HID's in these classics though. I've thought about HID's for my '70 also.
Jarred "Hot Rod" |1970 Pontiac LeMans Sport | Just a 350...
Hot_Rod is offline
post #3 of 19 (permalink) Old 03-23-2011, 08:55 AM
Quoted: 23 Post(s)
sounds like a weak ground, did you check the voltage at the headlights?
Instg8ter is offline
post #4 of 19 (permalink) Old 03-23-2011, 07:51 PM
put in halogen headlights, direct bulb and housing replacement. can put in as high wattage as you might like.
pontiac is offline
post #5 of 19 (permalink) Old 03-23-2011, 08:11 PM
Check your grounds first. And there are readily available Halogen sealed beam replacement bulbs
Eric Animal is offline
post #6 of 19 (permalink) Old 03-23-2011, 10:04 PM
Halogen bulbs will really put a strain on your electrical system if you just plug the bulbs in. Recommend if you go that route you look into using relays on the headlight wiring. Check out MadElectrical.com - Mad Enterprises for some ideas.
Russ
russosborne is offline
post #7 of 19 (permalink) Old 03-23-2011, 10:41 PM
Quoted: 23 Post(s)
Hey Russ, any way to wire Low/High lamps to my upper housing, i am gonna delete the Highbeams and put chrome screens in for dual Cold Air Intake and want to still have highbeams. i will be running 100 amp alt will that help with the strain on the Elec. system if i go halogen?
post #8 of 19 (permalink) Old 03-23-2011, 10:50 PM
It should be pretty straightforward. You need to change the headlight connector to one for a 2 way (low/high) bulb. Then just move the wiring from the old high beam connector to the high beam side of the new connector. The new connector will have 3 slots vs 2 on the 1 way lamps.
Using the relays you still will need 2, one for low and one for high. The problem is with the wiring and the voltage having to go thru the headlight switch, etc. See the link above, look for the headlight relay in the tech section for more details.
Damn, I am going to be doing the same thing on my 70. I saw the Spectre dual snorkle setup at a Pep Boys this last weekend. Just about like the old Ford Thunderbolt system. If you use them, or even not, go to their website, they have the piece to replace the headlight stuff and hook up the hoses.
I am trying not to get locked in at work, if you have any more questions I will try to answer them tomorrow night.
Russ
post #9 of 19 (permalink) Old 03-24-2011, 07:20 AM Thread Starter
Haven't checked the grounds, but I wanted to upgrade the lighting anyway. I'm already ugrading my wiring with another battery and a 140 amp alternator because I have a 15'' subwoofer in my trunk and it's running 1100 watts. any links to the halogen replacements? thanks
- Judson
post #10 of 19 (permalink) Old 03-24-2011, 07:51 AM
Quoted: 23 Post(s)
Same system i am going with Russ, the kit comes with both hoses and boots for behind the headlights. am gonna get some 1/4" stainless mesh and dome it to the shape of headlights and use it as a bug screen and headlight delete. Look on E-bay for the kit i picked up a new one for 40.00 (blem, but i have yet to find it) i think they list for 108.00 with hoses and clamps
upgrading brakes EEZ GOAT Drive train, suspension, alignment and brakes. 3 03-14-2011 01:08 PM
Found 69' #48 Heads zzomby 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 02-21-2010 04:02 PM
carb in a 69' GTO Luiz 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 12-27-2007 10:18 PM
68/69' Hideaway lights Marauder 1964-1974 Tempest, Lemans & GTO General Discussion 4 02-07-2005 03:22 PM
