vaccuum line - Pontiac GTO Forum
post #1 of 8 (permalink) Old 10-05-2011, 05:55 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
vaccuum line
On my new carb I need to run the dizzy vac line to a source.
on my old one there was only 1 port, now there are 2.
the one on the left is too large.
can I use the one above and to the right?
how can I tell?
thanks as always
Topkat is offline
post #2 of 8 (permalink) Old 10-05-2011, 09:04 PM
69Goatee's Avatar
I think The left port is full manifold vacuum, your dizzy line goes there. The upper is timed vacuum, above the throttle blades, no vacuum at idle. Is there a port for the PCV valve? I haven't messed with a Q-Jet in years, so I may be wrong.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
RESTORATION IN 1980...
NIN
69Goatee is offline
post #3 of 8 (permalink) Old 10-06-2011, 07:01 AM Thread Starter
Topkat's Avatar
the pcv valve dosnt go to the carb, it gets it vac off the intake man.
so are all the "full vacuum" ports off of the base plate?
Topkat is offline
post #4 of 8 (permalink) Old 10-06-2011, 07:41 AM
TK, The vacuum line for the distributor goes to a vac port BELOW the throttle plates. So, if all your other vac lines are hooked up, you may use a reducer on the large (left) port and hook the dizzy hose there. You may also check the smaller port (right) , if it pulls vacuum at IDLE then you can use it. The object is to use vac that is below the throttle plates. E
Eric Animal is offline
post #5 of 8 (permalink) Old 10-06-2011, 09:33 AM Thread Starter
Topkat's Avatar
How can it be below the t. plate?
thats the intake manif.
ty
Topkat is offline
post #6 of 8 (permalink) Old 10-06-2011, 10:35 AM
Quoted: 99 Post(s)
Because it is.... Look at it. the bottom outlet is in the baseplate below the throttle plates. You want to run manifold vacuum to the dizzy if you can. That's the factory original method with '67's.
post #7 of 8 (permalink) Old 10-06-2011, 12:35 PM
I've heard recommendations both ways --- that distributor vacuum should be taken from a ported (above the plates) or a non-ported (below the plates) source. Actually, try them both and see which one your engine seems to "like" the best, and use it.
BearGFR is online now
post #8 of 8 (permalink) Old 10-06-2011, 04:05 PM
Tk...TK...TK....how could you doubt your UE at this point???? That will cost you another Jim Beam!!! E
vaccuum lines Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 2 03-18-2011 03:00 PM
intake vaccuum Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 02-10-2011 05:53 PM
vaccuum Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 12 02-03-2011 09:13 AM
help off the line 05ls2gto Service, Maintenance and Technical Discussion 5 09-02-2005 10:10 AM
can't see my own sig line... radandy Gtoforum.com Site Help 1 12-28-2004 02:25 PM
