vaccuum lines - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-17-2011, 02:52 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
vaccuum lines
There are 2 vac. lines on the rear of my carb.
1 down on the throttle plate the other up higher.
I believe 1 goes to the distributer and the other to the Tranny.
How do I know which goes where?
thanks as always
Topkat is offline
post #2 of 3 (permalink) Old 03-17-2011, 03:02 PM
Quoted: 98 Post(s)
The big one goes to the power brake booster. The smaller one goes to the trans modulator. There is a special steel line that goes between the carb and the modulator. Mine is on its way from AMES as we speak.
post #3 of 3 (permalink) Old 03-18-2011, 03:00 PM
The vacuum modulator line that feeds into the carb will slide into the carbs port but you may need a small piece of rubber hose to splice the two together so the connection is tight. The end that feeds into the modulator itself, you'll need a piece of rubber vacuum hose to marry the two together. That's the way it is for a '70 anyway.
fuel lines Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 11 03-07-2011 09:30 AM
intake vaccuum Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 02-10-2011 05:53 PM
vaccuum Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 12 02-03-2011 09:13 AM
a/c vac lines? dsm25psi Service, Maintenance and Technical Discussion 4 07-24-2010 01:05 PM
vacume lines SIXT5GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 06-21-2010 12:00 PM
