vapor return - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-01-2011, 01:01 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
vapor return
Do I really need the vapor return line for my 67 Goat?
Can I just plug it up?
Something tells me it's there for a good reason?
thanks as always
Topkat is offline
post #2 of 3 (permalink) Old 02-01-2011, 02:14 PM
thanks as always
The reason was to try to help prevent issues with vapor-lock on hot days. The idea was that by recirculating a small amount of fuel from the pump back to the tank, it would keep fuel flowing in the system and help keep it cooler.
There's no reason not to use it, unless your fuel pump doesn't have the fitting for it. If that's the case, I'd consider getting a different pump instead of not using the line, but that's just me.
post #3 of 3 (permalink) Old 02-01-2011, 02:31 PM
Quoted: 118 Post(s)
I agree with Bear, as usual. Here's my experience with '67 return lines: My own '67 came with a HD cooling system. HD systems and cars with AC (which also had this system) used vapor return for cooling of fuel to prevent vapor lock. Two systems were used in '67: the line from the fuel pump to the return line, as Bear mentioned, and the type my car came with: a line off of the fuel filter. The fuel filter is an additional filter, mounts in a bracket off the T-stat, and has an extra outlet fitting that connects to a small steel line that bolts to the timing cover. This line connects to the line in the frame of the car. All of these parts are available from the vendors. I removed my vapor return in 1988 on a trip to Yellowstone, as my GTO was dying out with vapor lock every 10 miles or so. At Craters of the Moon, in 100 degree heat, I yanked all that #@%$ off of my engine and plugged the hoses. I still had issues, but limped home to CA, stopping every 50 miles or so to blow out my fuel lines. Turned out to be a collapsed sock at the fuel pick up in the tank itself. It was never vapor lock, it was running out of fuel as the sock folded up into itself and plugged the pick-up. My car still has the plugged off vapor return, 60,000 miles later. BUT, I ordered the filter, the bracket, and just yesterday cleaned up the steel return line....I am putting it back on. Can't hurt, and my car came with it. My 2cents. So, to summarize, fuel return is a good thing, and you have two correct options: run it off the pump or run it off the special filter.
Looks like GM might be recovering well. Does this mean that Pontiac may return? batmans The Lounge 29 08-14-2010 09:54 PM
65 clutch pedal return spring ponchonorm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 08-25-2009 07:05 PM
Who's using their tax return 4 mods? 6QTS11OZ The Lounge 13 02-11-2009 12:13 PM
Two-door Dodge Challenger to return? 05GTO The Lounge 13 06-17-2005 08:27 PM
