vapor return leak - Pontiac GTO Forum
post #1 of 6 (permalink) Old 08-07-2011, 02:46 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
vapor return leak
Howdy all
I have a fuel tank in need of flushing out, so I have by passed the feed and removed the vapor return line from the fuel pump and taped it up.
I have a boat gas can in the trunk with an external filter going to the f. pump.
I tried to crank the motor with the line to the carb disconnected to help get the polluted tank gas out of the pump and carb line but no fuel came out.
OK.........I hooked up the carb line and the car started fine........
BUT, after a couple minutes fuel started spraying out of the taped off vapor return line (on the pump).
Im guessing the fuel pump uses the vapor return to vent excess pressure back to the tank???
Can I hook the vrl back up without bad gas getting into my jury rigged system?
thanks as always
Topkat is offline
post #2 of 6 (permalink) Old 08-07-2011, 07:18 PM
Quoted: 98 Post(s)
Where on EARTH have you been? There was a whole thread dedicated to your disappearance and possible demise! Yikes! Step one: get a fire extinguisher. Step 2: make sure its dated, rated, and fully charged. Step 3: get rid of the funky gas and install the real gas tank and install the fuel lines as they should be: factory. You need to do it anyway, why not now. I have seen more stuff burned up and blown up doing what you're doing. Not trying to be harsh, just trying to save your car and house. Vapor return is to keep the fuel circulating, which cools it and prevents vapor lock. It is not standard, but is optional with GTO's that have a heavy duty cooling system for A/C, trailer towing, etc. Vapor return is a Good Thing. Welcome back!!!
post #3 of 6 (permalink) Old 08-07-2011, 07:40 PM Thread Starter
Topkat's Avatar
Thanks Gee................I'z been crabbing and salmon fishing, while saving what $'s I could to get my gas tank and brakes "fixed"
we're having it towed to the shop tuesday
appreciate your concern and good advise.
Topkat is offline
post #4 of 6 (permalink) Old 08-08-2011, 10:44 AM
TK, How much are you gonna be charged for a clean out job on the old tank....a new one is around $200...they are easy to install also. Might be something to consider as your tank could be rusty from condensation inside, and never be the same as new.........E
Eric Animal is offline
post #5 of 6 (permalink) Old 08-08-2011, 10:57 AM
Quoted: 98 Post(s)
I sure wish I were closer....salmon and crab sound pretty good to me!!!!!!
post #6 of 6 (permalink) Old 08-08-2011, 11:01 AM
Originally Posted by Topkat View Post
Howdy all
thanks as always
there is pressure in that line. you cant tape it off. you have to use hose and hose clamps.
freethinker is offline
throttle return spring Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 0 03-09-2011 06:28 PM
vapor return Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 2 02-01-2011 02:31 PM
Looks like GM might be recovering well. Does this mean that Pontiac may return? batmans The Lounge 29 08-14-2010 09:54 PM
Who's using their tax return 4 mods? 6QTS11OZ The Lounge 13 02-11-2009 12:13 PM
