Vinyl Top removal - Pontiac GTO Forum
post #1 of 13 (permalink) Old 07-02-2011, 08:11 PM Thread Starter
Vinyl Top removal
i was curious if anyone has done this and kept it off because they didnt like the looks. if so is there any difference body line wise if you wanted to keep it off and make it jsut a normal hardtop?
MotoCrazy is offline
post #2 of 13 (permalink) Old 07-02-2011, 08:31 PM
My 69 had a vinyl top (what was left of it) and I did'nt replace it.
Just gotta fill in the trim holes.
post #3 of 13 (permalink) Old 07-02-2011, 10:45 PM Thread Starter
ah sweet...what did u use to fill it? duraglass? weld?
post #4 of 13 (permalink) Old 07-02-2011, 10:56 PM
69Goatee's Avatar
I had to fill the holes and grind down the pins and finish the lead seams on my 69. The chrome drip rail strips didn't fit right afterwards, so I am finishing the rails that are attached to the roof and painting them body color. I had a little surface rust on the panel between the rear window and trunk lid, a skim coat of filler took care of that. I welded the holes closed.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
RESTORATION IN 1980...
NIN
69Goatee is offline
post #5 of 13 (permalink) Old 07-02-2011, 11:06 PM
Thumpin455's Avatar
I tore the vinyl top off my 67 Cougar, it was heavily pitted under it. I welded the trim holes. Pontiac A body trim is different at the quarter glass if you have a vinyl top on it since it connects to the piece that goes around the side glass. You would have to source that piece to change it. Or you can leave the trim on it and just not replace the top, Ive seen it like that and some like it. I just weld the holes up.
Thumpin455 is offline
post #6 of 13 (permalink) Old 07-03-2011, 08:17 AM
Must weld holes. Don't half ass it.
post #7 of 13 (permalink) Old 07-03-2011, 08:22 AM
Weld the holes! You might need to re shape the drip rail moldings depending on the YEAR your car is. Try to save the Vinyl trim as some people want them and will BUY them form you. E
Eric Animal is offline
post #8 of 13 (permalink) Old 07-03-2011, 08:58 AM
Thumpin455's Avatar
yeah I assumed later cars, early cars had the same trim pieces.
post #9 of 13 (permalink) Old 07-03-2011, 10:27 AM Thread Starter
well im still looking for a car, but im aiming at the 68-69 body styles. ive been crusiing craigslist and had seen one or two with the vinyl tops and wondered what kinda pita it would be to remove and if so, what im looking at body wise like seems and stuff...just wana make sure as opposed to getting one with a vinyle top, ripping it off, and then finding i just screwd myself
post #10 of 13 (permalink) Old 07-03-2011, 10:35 AM
Just buy the most solid/complete car you can.
Rust is a b*tch.
So is finding parts you did'nt know were "rare" until you needed them.
Vinyl top installation AMT1379 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 10-18-2010 10:42 AM
vinyl top ques edp 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 07-24-2009 06:34 AM
Removal of vinyl top chome Pogi 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 10-28-2008 03:24 PM
