Voltage a bit high - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-01-2013, 04:58 PM Thread Starter
waltcoleman's Avatar
Voltage a bit high
Tested voltage with a multimeter...testing about 12.8v at the battery with the car off, then watched it climb slowly to over 14.5v after I started the car and let it idle. Are those numbers too high and indicative of a voltage regulator problem?
waltcoleman is offline
post #2 of 4 (permalink) Old 06-01-2013, 05:26 PM
Perfect!!
post #3 of 4 (permalink) Old 06-02-2013, 11:02 AM
jmt455's Avatar
^X2!
Exactly what they should be!
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #4 of 4 (permalink) Old 06-02-2013, 04:54 PM Thread Starter
Cool thanks...I'm installing a voltage meter under the dash and though I'd baseline the numbers at the battery to compare versus the meter. I was worried they may be a bit high.
losing voltage simmons68 1964-1974 Tempest, Lemans & GTO General Discussion 4 05-27-2013 11:07 AM
`66 ignition voltage Rukee 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 08-02-2011 04:29 PM
voltage regulator Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 12-04-2010 04:43 PM
System Voltage - O6 GTO bg2m8o Service, Maintenance and Technical Discussion 7 10-20-2006 01:38 PM
voltage regulator wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-13-2006 11:49 AM
