Walking the body off - Pontiac GTO Forum
post #1 of 12 (permalink) Old 11-09-2009, 12:25 PM Thread Starter
MaL
MaL's Avatar
Send a message via AIM to MaL
My goal is to walk the stripped down body onto a trailer and taking it 10 miles down the road to the body shop.
I am keeping the frame so I can rebuild the engine and transmission.
How much does the body shell weigh? I have six guys helping me carry it out.
Is it a bad idea to have the body laying flat on the trailer? Would the weight crush the rocker panels? I could always put it on blocks on the trailer and then strap it all down.
Any tip/tricks you can think of to make this move easier (smarter)?
MaL is offline
post #2 of 12 (permalink) Old 11-09-2009, 01:16 PM
You should be able to move it with that much help. You might damage the rockers a little if you set it flat. If there is any way for you to set it up on the trailer off of the rockers that would be a better way to avoid damage.
Thanks,
Joe Kubiak
Sales / Tech
BMR Fabrication
813-986-9302 Phone
813-986-8055 Fax
[email protected]
www.BMRFabrication.com
BMR Sales is offline
post #3 of 12 (permalink) Old 11-09-2009, 02:08 PM
Place 4-6 old tires under the floor and trunk pans, I transported mine on a rotessorie and let it rest on several tires for the trip to the sand blaster.
05GTO is offline
post #4 of 12 (permalink) Old 11-09-2009, 02:31 PM
Quoted: 103 Post(s)
You won't have a problem with 6 guys. You wont damage the rockers, either. My concern would be twisting of the shell. Be careful, and maybe brace the door openings with some angle iron to prevent sag.
post #5 of 12 (permalink) Old 11-09-2009, 03:23 PM
Place the tires on the trailer so that the body mount locations sit on them. You won't damage it that way, as that is where it sat on the chassis.
Eric Animal is offline
post #6 of 12 (permalink) Old 11-09-2009, 04:10 PM
crustysack's Avatar
I will agree with comments above, 6 guys no problem, place tires under the body at the body mounts and you should have no problem, maybe a little late but you should remove the glass and check under the windshield and back glass for any issues, that is a very common area to find some trouble.I also noticed the rear wheel well trim is in place- these need to be removed for paint - you will save $$ if you do those things yourself
crustysack is offline
post #7 of 12 (permalink) Old 11-09-2009, 07:29 PM
05GTO is offline
post #8 of 12 (permalink) Old 11-10-2009, 12:22 PM Thread Starter
MaL
MaL's Avatar
Tires! Of course! Good thinking.
I picked up six old tires up for free this morning. This Saturday is the move.
I pulled the trim from the wheel well and now have to figure out the easy way to remove the glass, it's dangerously cracked in places.
I appreciate all your feedback.
Phew and I thought I was going to have to go with plan-B.
MaL is offline
post #9 of 12 (permalink) Old 11-10-2009, 03:37 PM
Piano wire wrapped around a couple pieces of wood for handles. One bare end of the wire work through under the glass to the other side past the rubber goo glueing it in. Tie your other handle on and work that all the way around the window. It should lift out when you get it all the way around.
post #10 of 12 (permalink) Old 11-11-2009, 09:18 PM
67 Basket Case Restorer
Too Many Projects's Avatar
I would use longer planks and get the jack stands outside the tires. You can roll the frame out and the trailer under. Pick one end up, get the plank out and the tires under, repeat. Done.....
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
64 Tempest Update - Body is off 64phil 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 02-06-2009 01:11 PM
70 GTO Hardtop restoration...Where to begin...? sd-slider 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 17 01-29-2008 07:17 AM
looking for aftermarket body for '65 goat tee102060 Exterior Discussions 0 10-23-2007 12:19 AM
'67 GTO body repairs? Yardbuck 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 3 02-02-2007 02:23 PM
Body shops RipTheSix Service, Maintenance and Technical Discussion 1 07-28-2006 10:38 PM
