Washer pump - Pontiac GTO Forum
post #1 of 3 (permalink) Old 08-15-2019, 09:08 PM Thread Starter
Quoted: 13 Post(s)
Washer pump
Hi,
Looking for some guidance on wiper washer problem.washer on my 70 Gto. pump relay and cam all seem ok,wipers work but no squirt.
I swapped out another pump but still nothing.
The switch maybe.I'm. Not hearing anything when i depress the dash switch,but not sure if i should be either,
Thanks for any input.
Bob
rheckman is offline
post #2 of 3 (permalink) Old 08-16-2019, 02:17 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
need to pull the plug at the pump and put your continuity tester on the wire and see if you have power
pushing the squirter button
the pumps click fairly loud at thebeginning of the cycle
not quiet like the motor
BLK69JUDGE is online now
post #3 of 3 (permalink) Old 08-16-2019, 09:04 PM Thread Starter
Quoted: 13 Post(s)
Thanks,
Not sure what's going on im not getting any readings from multimeter in continuity or ohms,touching the female spade plug that goes into the pump.
rheckman is offline
