water pump - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-04-2011, 03:39 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
water pump
It's amazing how useless the '67 service manual is.........
Do I need to put "goo" on the water pump bolts and nuts?
pours another round......
Topkat is offline
post #2 of 4 (permalink) Old 02-04-2011, 03:55 PM
Not on the nuts and bolts. I like to use a little bit of RTV selant on the gaskets.
dimitri is offline
post #3 of 4 (permalink) Old 02-04-2011, 05:15 PM
Quoted: 118 Post(s)
I agree. And be sure your spacer plate assembly is positioned correctly. It "fits" only one way, and in a kind of sweet spot. Put that in, and gently position the pump. Torque the pump evenly, and not gorilla tight. Pass the 1800...sounds good to me!!
post #4 of 4 (permalink) Old 03-06-2011, 12:27 AM
use antiseize on the threads where the bolts go into the timing cover threaded holes. Since cover is aluminium and bolts are carbon steel, they will corrode together. On the studs, it is not necessary.
pontiac is offline
water pump Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 11-22-2010 01:02 PM
water pump questions , again 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 06-07-2010 10:26 PM
Water pump has gone twice in 2 months sjago13 Service, Maintenance and Technical Discussion 6 01-04-2010 04:00 PM
Wrong Water pump Joust 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 07-02-2009 09:50 AM
Electric water pump ouijaguy Service, Maintenance and Technical Discussion 0 05-12-2005 03:49 PM
