Water Pump Questions - Pontiac GTO Forum
post #1 of 5 (permalink) Old 01-27-2019, 07:45 PM Thread Starter
I have a 65 tri power four speed w/AC. It runs a consistent 175-180 except in town w/AC on. I'm considering a Flowkooler 8 bolt water pump and wondered if anyone out there has experience with them and if so do you clearance the divider plates like with the stock pumps? I've already upgraded to a 160 high flow thermostat, aluminum radiator and clearanced my current my stock cast pump impeller and plate.
Johnhw is offline
post #2 of 5 (permalink) Old 01-27-2019, 07:54 PM
MidnightAuto's Avatar
I dropped in a 8 bolt flow kooler. The clearance is better than stock, but could be tightened further. I did. I wrote about in another post. Search on my handle. Two clearances to solve for. Motor run engine ice cold now. I did drop in a cold case radiator too...
MidnightAuto is offline
post #3 of 5 (permalink) Old 01-28-2019, 09:33 AM Thread Starter
Thanks for the response Midnight. I'm going to order the Flowkooler today. I'm tired of having to turn the a/c off in town with the top up. I don't know if a Cold-case would have cooled better but my goat is bone stock and I want to keep it looking that way. I used the US Radiator 1" two tube that has the original stamped tanks and it made a huge difference. A little black paint and it looks factory.
Johnhw is offline
post #4 of 5 (permalink) Old 01-29-2019, 08:03 AM
One warning- on re-assembly I did not notice my divider plate was not aligned at the bottom of the pump. I tightened those bottom bolts and cracked the flow kooler. The pump actuallly has a warning in the box about overtightening and cracking...in retrospect now I understand why. So the second flowkooler went in fine....
post #5 of 5 (permalink) Old 01-30-2019, 12:58 PM
Quoted: 98 Post(s)
Back in the day, these cars when new would run 215-220 all day long on hot days with the AC on. Harms absolutely nothing, unless your car is more prone to detonation at higher temps. The sweet spot for these engines to run at to burn off all the condensation in the crankcase and to be thermally efficient is about 190-195 degrees. You didn't state if your car was overheating or not....if it runs at over 230 and pukes coolant when you shut it down, that is overheating. If it simply runs 210-220 with the AC on when it is hot outside, that is a non-problem.
1966 Original Fuel Pump and Water Pump Part numbers redandwhite66 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 07-19-2018 04:18 PM
water pump questions , again 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 06-07-2010 10:26 PM
water pump bolt running throug intake manifold wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 1 05-02-2006 09:35 PM
Electric water pump ouijaguy Service, Maintenance and Technical Discussion 0 05-12-2005 03:49 PM
