Water VS Antifreeze - Pontiac GTO Forum
post #1 of 6 (permalink) Old 03-19-2014, 07:44 PM Thread Starter
SCG Pontiac's Avatar
Water VS Antifreeze
This picture shows the results of previous owner filling the cooling system on a beautiful 1968 Firebird 400 with a garden hose. He told us he read somewhere on a forum that water cooled better than antifreeze. Truth is water does exchange heat quicker than antifreeze but someone should have told him about rust inhibitors. This engine only has 750 miles on a very high end rebuild but the rebuild was 6 years ago. He obviously didn't drive the car much. The amazing thing is it runs perfect and only slightly warm. The timing cover was completly welded to the block from rust. It took a BIG hammer and a torch to remove it. Both studs snapped of in the block ( really fun). The moral of this story... Antifreeze is cheaper than water.Click image for larger version
SCG Pontiac is offline
post #2 of 6 (permalink) Old 03-19-2014, 08:14 PM
Damn! I want to add that you should only used de-ionized water also when mixing with antifreeze.
post #3 of 6 (permalink) Old 03-19-2014, 10:07 PM Thread Starter
ALKYGTO,
Good point on the water. These aluminum timing covers may not rust but they dissolve like you poured battery acid on them when you use hard calcium filled water
post #4 of 6 (permalink) Old 03-20-2014, 12:07 PM
old-goat's Avatar
A few years ago, a trucker came into our shop with a cracked block - he just couldn't understand how his block could be cracked because he only used "creek water" , and that creek never freezes......
old-goat is offline
post #5 of 6 (permalink) Old 03-20-2014, 01:53 PM
700Rocket's Avatar
it's hard to fix stupid.
700Rocket is offline
post #6 of 6 (permalink) Old 03-20-2014, 02:40 PM
You cant fix stupid haha
68GTO_MAN is offline
Source of antifreeze leak SlamminGears65Goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 05-12-2013 12:30 PM
Smelling Antifreeze sutliffhl21 2004-2006 GTO General Discussion 1 04-21-2006 09:33 PM
Dexcool antifreeze Volley Service, Maintenance and Technical Discussion 1 01-01-2005 12:12 AM
Antifreeze leak heatherGTO Service, Maintenance and Technical Discussion 5 11-12-2004 09:58 AM
leaking antifreeze heatherGTO 2004-2006 GTO General Discussion 1 11-10-2004 12:36 PM
