What is a 1968 GTO Rearend Worth - Pontiac GTO Forum
post #1 of 4 (permalink) Old 12-15-2014, 06:48 PM Thread Starter
What is a ZH Code 355 1968 Complete Rearend Worth ??
ljc3822 is offline
post #2 of 4 (permalink) Old 12-15-2014, 07:24 PM
Quoted: 368 Post(s)
Whatever someone is willing to pay for it. To the best of my knowledge, the fact that it came from a GTO probably has no bearing on price as the rear-end could have come, or been under, any Pontiac GTO, Lemans, or Tempest. The fact that it seems to be a posi unit does make it worth more.
This shows the ZH code as being a 1965-1966 rear end. GTOAxleCodes Here it shows up in 1968 under Tempest http://www.wallaceracing.com/axledata2.htm
Do you know it to be original to the car? Best guess would be in the $150-$250 range if I were in need of it only because it was a posi rear end. 3.55's are a nice acceleration gear, but not a good gas mileage gear, and I would not want these in my car if I were planning on doing highway driving. So you have plus & minus with this rear-end.
post #3 of 4 (permalink) Old 12-16-2014, 07:33 AM
To the guy that needs it.....maybe $250 - $350. Not as easy to find these days as they used to be. If it is original to your car I would keep it. I wish I would have kept mine. That is the only original part to my car that I did sell and I regret it.
post #4 of 4 (permalink) Old 12-16-2014, 12:13 PM
Quoted: 103 Post(s)
Out where I am, to the guy who needs it, if the posi is in good shape: $800 all day long. To anybody else, $350-$400 is the going rate. Out here in CA, you can't get a 3.55 one-legger for $250-$350...
1967 gto conv rearend gears 3.23 hall85296 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 04-30-2014 07:48 PM
70 GTO 455 HO 12 Bolt 3:31 Posi Rearend XU Code dt69usa Drive train, suspension, alignment and brakes. 1 06-15-2012 05:22 PM
65 Pontiac GTO Rearend shovel55 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 09-23-2011 06:49 PM
1964 GTO rearend HELP!!!! skunk39 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 06-18-2011 04:39 PM
