What is it #22 - Pontiac GTO Forum
post #1 of 10 (permalink) Old 01-07-2011, 04:16 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
What is it #22
I found 4 of these at the GTO's grave site.
any ideas? They are 5'' long.
Thanks as always!
Topkat is offline
post #2 of 10 (permalink) Old 01-07-2011, 07:50 AM
Screw in rocker studs?
Eric Animal is offline
post #3 of 10 (permalink) Old 01-07-2011, 09:00 AM
FNG69's Avatar
Lower Head Bolt!! The top head bolts are under the value covers, the lowers you can see in engine bay. The top threads above the head of the bolt are for a nut to hold the battery cable, battery cable tube, or some accessory item...
FNG69 is offline
post #4 of 10 (permalink) Old 01-07-2011, 11:49 AM
On mine I have in the middle 3 bolts under the valve cover holding the splash shields on. One holding the negative battery cable. I am also pretty sure it held down the heat riser sheet metal that the round preheat tube to the air cleaner was connected to.
dimitri is offline
post #5 of 10 (permalink) Old 01-07-2011, 01:16 PM
Quoted: 117 Post(s)
You need two of these head bolts at least. I don't think I've ever seen 5 on a car, but it's possible. Yes, one is for the neg batt cable to bolt to, and the other is for the heat tube where the pos cable goes to the starter at the rear of the head. See underhood photos for reference. Driver's side head, lower bolts.
post #6 of 10 (permalink) Old 01-07-2011, 04:09 PM
Musta been 1/2 asleep....5 1/2 " is a bit long for a rocker stud!
post #7 of 10 (permalink) Old 01-07-2011, 05:33 PM
Unless you have some really heavy duty lift going on!!!
post #8 of 10 (permalink) Old 01-08-2011, 08:23 AM
Ahhhhh, there you are!
post #9 of 10 (permalink) Old 01-08-2011, 10:26 AM
On my car the battery is bolted to it.
bullet20cc is offline
post #10 of 10 (permalink) Old 01-08-2011, 02:58 PM
the NEGATIVE cable.....
