What is it #33 - Pontiac GTO Forum
post #1 of 7 (permalink) Old 03-10-2011, 07:34 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
What is it #33
What is the thing with the wires blocking my accelerator pedal wide open?
thanks and a beer
Topkat is offline
post #2 of 7 (permalink) Old 03-10-2011, 07:53 PM
66tempestGT's Avatar
kickdown switch for the trans. put the pedal on the other side and it will work better.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #3 of 7 (permalink) Old 03-10-2011, 08:13 PM Thread Starter
Topkat's Avatar
Wow, that's cool thank you!
er..............what does it do?
As far as i knew(lol) the only wire going to my trans was for the Tac
thanks again
Topkat is offline
post #4 of 7 (permalink) Old 03-10-2011, 10:46 PM
makes the trans downshift when you press the pedal way down. (passing gear) it should be the only wire going to the trans. tach gets its signal from the ignition.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
post #5 of 7 (permalink) Old 03-11-2011, 12:28 AM
likethat's Avatar
It is for the 400 turbo. It drops into passing gear(automatic down shift) from an electrical solenoid on the side of the trans. Unlike the 350 turbo, that uses a cable that runs from the carb to inside the trans next to the cooler lines.
So that is the switch to run the solenoid at close to full throttle. I am sure they put it inside the car, so it would last longer then being in the elements
67 GTO H.O. Convert 4spd
likethat is offline
post #6 of 7 (permalink) Old 03-11-2011, 08:57 PM
that switch operates st300 2 speed also.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
post #7 of 7 (permalink) Old 03-11-2011, 10:34 PM
likethat's Avatar
lol yea that is true as my 66 gto had one for the old 2speed trans. oops brain fart
likethat is offline
