What is this? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 07-23-2011, 06:23 PM Thread Starter
68GTO4004Spd's Avatar
What is this?
What is this and where does it go?
68GTO4004Spd is offline
post #2 of 7 (permalink) Old 07-23-2011, 06:29 PM
That's an oil dripper. It goes under the valve cover, there should be a pair.
Eric Animal is offline
post #3 of 7 (permalink) Old 07-23-2011, 07:36 PM Thread Starter
I have both, my engine builder didn't install them, are they important? Which side goes up?
post #4 of 7 (permalink) Old 07-23-2011, 11:05 PM
did he leave in the studded head bolts they mount to or did he replace all the head bolts with new ones? if you changed to non stock rockers, valve covers, etc, they might not fit anymore.
pontiac is offline
post #5 of 7 (permalink) Old 07-24-2011, 08:08 AM
and flatside up
post #6 of 7 (permalink) Old 07-24-2011, 01:15 PM
The idea is to catch the oil spray from the pushrods and drip it down onto the valve stem area. If anything has been modified on the top end (roller rockers, etc. chances are they won't fit any more. Some folks say they're required, some don't. If everything on the top end of the motor is still stock they certainly can't hurt. If you've ever run the motor with the valve covers off then you know that oil tends to go "everywhere" anyway.
I don't have them on my 461 because there's no way to mount them what with my roller rockers and stud girdles.
Your call.
BearGFR is online now
post #7 of 7 (permalink) Old 07-25-2011, 07:41 AM Thread Starter
My valve train is all stock, I don't know if the builder put the studs back in or not, I have not seen it with the valve covers off. I will probably put them back in, I just hate to disturb the gasket and have it not seal.
