What is involved in swapping to a 4speed? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 03-08-2011, 06:01 PM Thread Starter
I know I need the clutch, PP, TO bearing, bellhousing. But what about pedals and z-bar mount? How difficult is it to install these?
Wade
BlackRat is offline
post #2 of 2 (permalink) Old 03-09-2011, 01:32 PM
You will need pedals...not too difficult. A flywheel and pilot bearing. A shifter and maybe a console. Is the car currently a column shift?...if so you need a different steering column. You can save a LOT of hassle and BS with clutch linkage by using a hydraulic throw out bearing...................also, consider a 5 or 6 speed, you are doing the labor anyway. Eric
Eric Animal is offline
1964 GTO 4speed carb cfm? JWatkins 1964-1974 Tempest, Lemans & GTO General Discussion 7 10-11-2011 02:45 PM
05-04 Swapping goatCurious Exterior Discussions 9 06-10-2010 03:22 PM
converting to a 4speed.flywheel help? Pontiac Tempest Cstm 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-01-2008 09:30 PM
4speed gtocrazed 1964-1974 Tempest, Lemans & GTO General Discussion 1 06-03-2008 12:34 PM
4speed autotranny question Eric Animal 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 03-03-2008 07:23 PM
