What Oil to use for a Pontiac 400 - Pontiac GTO Forum
post #1 of 11 (permalink) Old 10-03-2013, 09:36 PM Thread Starter
67 GTO's Avatar
Hey guys, simple but crucial question, what is the right oil to use in a Pontiac 400? 10W 30 , 10w 40? How many quarts as well ?It has a roller cam in it as well. Its a simple question but important.
67 GTO is offline
post #2 of 11 (permalink) Old 10-03-2013, 09:41 PM
Where are you located, in colder climates a lower viscosity is preferred,
05GTO is offline
post #3 of 11 (permalink) Old 10-03-2013, 09:57 PM Thread Starter
67 GTO's Avatar
I forgot to mention its a 67, and I am located In New Jersey!!
67 GTO is offline
post #4 of 11 (permalink) Old 10-04-2013, 08:58 AM
Recommend Brad Penn 10W 30. Most likely 5 quarts with a filter change. Matt
Matthew is offline
post #5 of 11 (permalink) Old 10-05-2013, 08:03 PM Thread Starter
67 GTO's Avatar
is the 10w 30 to light for these old motors?
67 GTO is offline
post #6 of 11 (permalink) Old 10-05-2013, 09:19 PM
jmt455's Avatar
No, 10W30 is not too light...unless that engine was specifically built for racing us and has unique oiling requirements, or if it needs higher viscosity lubricant due to component wear.
The OEM oil recommendations (from the Factory Service Manuals) were as follows:
For operation in temperatures from -30F to +20F: 5W, 5W-20 or 5W-30
For operation in temperatures from 0F to 60F: 10W, 5W-30, 10W-30, 10W-40
For operation in temperatures from 20F to 100F or above: 20W, 10W-30, 10W-40, 20W-40
I also use the Brad Penn 10W-30 that Matthew recommended. I believe the higher zinc content is better suited to the flat tappet cams/lifters. If I had a roller cam & lifters, I would probably use a "normal" 10W-30 brand.
Double check the capacity; I think your 400 should take 6 quarts with a filter change.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #7 of 11 (permalink) Old 10-06-2013, 10:21 AM
A lot depends on how the engine is built. Are bearing clearances a little on the tight side? a little on the loose side? What kind of camshaft are you running? (flat tappet or roller). What's the climate like where the car's going to be most of the time? How are you going to drive it? What's the rest of your oiling system like? (pump, pan capacity, etc) --- and how well is it sealed? ( a leaky rear main can make running synthetic oil very expensive )
In my car, I'm running Rotella T 15w-40. It's a "performance" engine build (bearings just a tiny tiny bit on the "loose" side), it's running a solid roller cam, I live in Texas, I drive it mostly on the street and also race it some, I'm running the Snelling M54DS pump with this backing plate this pickup, and this oil pan, and (sorry to say) my rear main seal leaks a little.
My factory oil pressure gauge shows 75 psi on a cold engine, about 65 psi at cruise with a warm engine, and about 20 psi at idle with a warm engine.
post #8 of 11 (permalink) Old 10-06-2013, 03:29 PM Thread Starter
67 GTO's Avatar
Im not really sure on the specs on the motor because I did not do the rebuild. I do know it has a mild to heavy cam in it. I also live in New Jersey. Everything else is stock such as oil pan and oil pumps etc. ?
67 GTO is offline
post #9 of 11 (permalink) Old 10-06-2013, 03:31 PM
leeklm's Avatar
Looks like you have a roller cam, which means you have plenty of good options, and do not have to worry about the extra zinc. I have a flat tappet cam, and my engine guy recommended 15/40 with a zinc additive. With this combo, I managed to lose two lobes off a hyd cam within the first 1,000 miles.
When watching how long it took for 15/40 oil to get forced up through the pushrods and rockers on cold start, I stopped using it. I also read on Bobs the oil guy.com that the high detergent found in 15/40 diesel oil would actually offset the properties found in the zinc additives.
I have a relative that works for Amsoil, so he got a me a good deal on a case of zrod 10/30 high zinc oil. Short of a cam issue like I originally had, I do not put nearly enough miles on the car to tell any difference on oil one way or the other. I will say however, my solid lifter engine feels smooth with the zrod oil, but maybe I am just eating up the marketing hype
Being that you live in a cooler climate like I do, and likely start the car on cool fall nights, I would run a name brand 10/30 or 10/40 oil. A synthetic blend might be a good option as well, and maybe provide a little better start up protection.
leeklm is offline
post #10 of 11 (permalink) Old 10-09-2013, 12:21 PM
Quoted: 98 Post(s)
Factory fill for a '67 400 was 10w 30. My stock '67 GTO 400 engine holds SEVEN quarts with filter. My '65 389 holds only 6. Later 400's held less. Have been using 15/40 Rotella in the '67 for about 10 years and 20,000 miles with no issues with the 068 cam I installed 25 years ago whatsoever. I am in the lighter-viscosity-is-better school of thought, though, and would think Brad Penn 10w30 with the ZDDP would be a great choice.
Oil for 69 400 Darth Menace 1964-1974 Tempest, Lemans & GTO General Discussion 3 08-21-2013 04:37 PM
Pontiac 400 oil pan torque spec and sequence Pontiac_Madness 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 01-22-2012 11:12 AM
Oil pan Gasket installation on a Pontiac 400 Pontiac_Madness 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 01-13-2012 06:03 PM
69 XH 400 pushing oil Backup 1964-1974 Tempest, Lemans & GTO General Discussion 6 01-09-2011 09:32 AM
oil type for 70 ys 400 even steven 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 07-06-2009 01:05 PM
