What Oil's in Your Poncho? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 11-20-2011, 01:44 PM Thread Starter
kilkm68's Avatar
Everyone seems to have their own opinion. I'd like to know what kind of oil you guys are running in your big HP Pontiac's. I've been advised and use conventional 20W50. Who likes synthetics and what's your opinions on additives such as ZDDP or TPFE?
kilkm68 is offline
post #2 of 7 (permalink) Old 11-20-2011, 05:04 PM
2006BlueGoat's Avatar
In all of my older cars I run Mobil 1 15W50. It's formulated for earlier design engines and has the necessary ZDDP already in it. I believe it's either 1200ppm or 1500ppm, I've forgotten which (you can check the website for the exact amount). I've never had an oil related failure while using it.
2006BlueGoat is offline
post #3 of 7 (permalink) Old 11-20-2011, 06:45 PM
I run Brad Penn 20/50. It's Green.
post #4 of 7 (permalink) Old 11-20-2011, 07:06 PM
Havoline 10-40 conventional in my 461, mostly because that's what Mr. PBody recommended. I'm a big fan of synthetics though.
post #5 of 7 (permalink) Old 11-20-2011, 09:58 PM
646904GTO's Avatar
In my 04 Mobil one 5w30 synthetic
In my 64 Delo 400 30w
In my 69 Mobil one 15-50 synthetic
The reason behind the Delo 400 is it is a heavy duty gas or diesel engine oil designed for severe duty and when that car comes out it goes home all hot and bothered. I routinely do 6,000 RPM shifts and she lives.
1969 400 T400 auto 2nd owner
1973 Challenger 360/727
1931 Ford Model A
646904GTO is offline
post #6 of 7 (permalink) Old 11-21-2011, 02:47 PM
Quoted: 117 Post(s)
Rotella 15/40 with ZDDP additive in the '67; and some Valvoline 10/30 in the '65 from a case I bought in the '90's that still has ZDDP in it. Soon to be Brad Penn in both cars as I understand even the diesel spec Rotella and Delo is low on ZDDP these days. I run full synthetic in my 4Runner in case I blow up the cooling system in the desert and have to drive out no matter how hot it gets. Synthetic oil will still flow at over 350 degrees. I don't use 20/50 oil in anything. I used to, but now I know better. Engines with factory tolerances do not need such a thick, power robbing oil, IMHO. I too am a bign fan of synthetic oils, but it's "overkill" most of the time. The big issue is regular changes, and ZDDP with flat tappet camshafts.
post #7 of 7 (permalink) Old 11-21-2011, 08:59 PM
68GTO4004Spd's Avatar
I'm going to run Valvaline VR-1 racing oil 10W30 once I get the break in oil out of it.
Kilkm68 you need to post some pics of that car.
68GTO4004Spd is offline
Where Did The Name "poncho Motor" Come From? take5 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 34 02-04-2010 09:57 PM
Well, It aint a Poncho, but... Ranger01 1964-1974 Tempest, Lemans & GTO General Discussion 10 10-05-2009 09:59 AM
Question about 400 Poncho heads Poncho Dan 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 07-10-2009 08:45 PM
AMC guy in Poncho land!! Rebel25A Member Introductions 2 12-29-2006 04:51 PM
