What tri power intake do i have? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 07-14-2011, 04:55 PM Thread Starter
Hello I'm wanting to install tri power on my 65. The intake i have has numbers [a195] [3778818 can someone help id this plenum?
triplets is offline
post #2 of 7 (permalink) Old 07-14-2011, 05:00 PM
Pontiacpurebrred's Avatar
I think it's probably 9778818 not 3778818 and here is your info.
9778818 1965 389 338, 360 Rochester 3x2
9778818 1965 421 356, 376 Rochester 3x2
Pontiacpurebrred is offline
post #3 of 7 (permalink) Old 07-14-2011, 08:11 PM Thread Starter
Sweet it looks to be the correct one.May i ask where you obtained such information?
triplets is offline
post #4 of 7 (permalink) Old 07-14-2011, 09:28 PM
The other code should be the date, (Jan. 19, 1965)
05GTO is offline
post #5 of 7 (permalink) Old 07-15-2011, 01:09 AM
google search gets you that info.
pontiac is offline
post #6 of 7 (permalink) Old 07-15-2011, 01:00 PM
I actually found it on Pontiac Power DOT net. I also use Year One and Wallace Racing. GREAT resources when searching codes for engines, cylinder heads, intakes, carbs, the works. Usually you can find it at one of the three and I usually compare across sites to make sure everything matches.
post #7 of 7 (permalink) Old 07-15-2011, 01:57 PM Thread Starter
Thanks you guys so much. This fourm rocks!
triplets is offline
Which tri-power intake was best? 65GTO421HO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 06-24-2009 08:53 PM
Tri-Power Intake 80transam Intake and Exhaust Discussions 7 10-15-2008 07:55 PM
