What's it worth? - Pontiac GTO Forum
post #1 of 12 (permalink) Old 01-13-2008, 12:53 PM Thread Starter
What's it worth?
I am looking at a 1967 GTO hard top. I know this is a hard question to answer due to the many unknowns, and variables. 400cu. in. tri-power ps pb 4 speed console. body APPEARS to be all metal,repro bumper (I think). Body is in 7.5-8 out of 10. Clean chassis, drum brakes, all lights work. INTERIOR--dash has Rallye Gauges? (clock indash,hood tach) repro dashpad, good carpet,BAD-seats appear to be correct frames however were reupholstered in cloth. New tires on rallye one wheels. What else should I mention?? Someone give me a ball park guesstimate of price.....Thanks, Eric
Eric Animal is offline
post #2 of 12 (permalink) Old 01-13-2008, 01:07 PM
Let this be a guide Eric.
low good high Price when New
Convertible $13,400 $40,300 $67,100 3,165
Hardtop 11,000 33,000 55,000 2,935
Sport Coupe (pillar/post) 10,800 32,300 53,900 2,871
1967 GTO Specifications - UltimateGTO.com
post #3 of 12 (permalink) Old 01-13-2008, 06:23 PM
Tri-Power's Avatar
keep in mind a tri-power was not avail. from the factory in '67, is it #s matching otherwise?
1966 GTO bored 389 Tri-Power, Powerglide(#'s Match)
{GTO, Lariat, Galaxie, Glastron, & Yamaha} -Tyler-
PURDUE AUTOMOTIVE PERFORMANCE ASSOCIATION PRESIDENT
Tri-Power is offline
post #4 of 12 (permalink) Old 01-13-2008, 08:10 PM Thread Starter
I knew the trips weren't factory in 67. I don't know yet if it is a #s matching car. I will find out. The PHS papers say the car was originally cameo white with gold interior.Headrest option with reclining passenger seat (no longer in car). I am not too concerned about originallity, mainly I want a clean straight body to work with.....if it is NOT a #s matching car, I will do a resto-mod. I want something I can drive.... THANKS for the input.....KEEP IT COMING!!! I have been out of the scene for 20 or so years. I am trying to overcome "digital shock" on the prices. Eric
post #5 of 12 (permalink) Old 01-13-2008, 09:43 PM
As mentioned above by GTO_Judge A 67 GTO in very good condition should bring $33K or more, for $33K the car should have the correct date codes and casting numbers; the car should match the data plate and PHS report, the paint should be in good condition and the tires should be good.
I would suggest deducting the cost of restoring the car to the above condition from $33,000.
I.E.
Nada value $33,000 minus engine rebuild=$ 4,000, brake rebuild = $500, new bushings = $500, transmission rebuild $ 500. New interior $2,000, correct rebuilt WT engine = $7,000, front clip R&R, $1000 and paint job, $5,000.
Hope this helps,
05GTO is online now
post #6 of 12 (permalink) Old 01-13-2008, 10:06 PM Thread Starter
Thanks! I figure the seller should give me the car plus 10,000 to fix it up!!! JUST KIDDING! All the help from you guys is appriciated. Eric
post #7 of 12 (permalink) Old 01-13-2008, 11:17 PM
I'm very likely wrong...but I thought that the first 2-3 months of '67 production that Pontiac did put Tri Powers in before switching to the single 4 barrel?
Plus where do you get a very good paint job for 5,000? What I've been quoted a couple of times for a Tyrol Blue over the non factory deep burgandy was 10,000! Maybe it'd be worth shipping my car to a less expensive but very good paint shop?
Enjoying this new site very much (I'm a brand new member)
Craig is offline
post #8 of 12 (permalink) Old 01-13-2008, 11:48 PM
Tri-Power's Avatar
Not sure if this will help you at all. in 2000 i bought my very naked 66 for $2k. It had no bumpers, no interior at all, no grills, not much at all, and the engine was completely seized from sitting for too long w/o aircleaners, or a hood. It did have some things going for it though. everything that was there was original, and relatively straight/rust free. Some pics of how it was when we saved it:
whithout completely totaling all of the receipts, we have about $20k in the car after original purchase price of $2k, also not counting all the hours cause that was just fun. this one sounds like it is in MUCH better shape so If your smart, there should be no way you could spend more than me. Just FYI.
post #9 of 12 (permalink) Old 01-14-2008, 07:46 AM Thread Starter
The one I am looking at SEEMS to be in 7.5 shape...I am afraid of the "repro smoke and mirrors effect".....ya' know when you buy something,and find out that it is a tiwanesse quick fix and it disintigrates on the way home.............The car looks pretty nice...I will drive it next week (this week) and post findings........All comments are welcome. Eric
post #10 of 12 (permalink) Old 01-14-2008, 11:11 AM
While you are there record the codes from the VIN tag, data plate, engine block, heads, transmission, differential.
Codes on the block will be located;
Front passenger side of block under the head you will have the engine letter code and the engine unit number.
Early 67 the casting number was located on the distributor pad, late 67 the casting number was relocated behind the #8 cylinder. The production date code is also located on the distributor pad.
The code for the heads are located on the center exhaust just above the manifold, should be 670 for 1967.
05GTO is online now
Help, 1972 Factory 455 GTO - Whats it worth epahl 1964-1974 Tempest, Lemans & GTO General Discussion 6 12-11-2007 03:04 PM
are catback's worth any hp gain? jmd Intake and Exhaust Discussions 12 02-01-2007 12:29 PM
Worth It ?? lotaguts 2004-2006 GTO General Discussion 10 01-21-2006 01:36 PM
automatic worth getting? deezdad 2004-2006 GTO General Discussion 9 03-22-2005 11:31 PM
CAI Worth it? adewan Service, Maintenance and Technical Discussion 20 02-09-2005 05:30 PM
