What's Wrong With This Picture-65 GTO - Pontiac GTO Forum
 3Likes
  • 3 Post By geeteeohguy
post #1 of 7 (permalink) Old 05-22-2019, 11:00 AM Thread Starter
renorealtors's Avatar
Quoted: 13 Post(s)
Hi All.
Is this steering linkage wrong? It hits the oil pan so much it is hard to turn the wheel and the stops don't hit, but the oil pan acts as one? Something tells me I have the wrong components and there should be way more clearance under the oil pan? Silly me with my OCD have to keep a clean shop and threw away the old steering parts!
I found this little problem lifting the motor to clearance the rag joint as it was hitting the header. The PS pump is the original but I replaced everything else.
ID:	119163   Click image for larger version
ID:	119165   Click image for larger version
ID:	119167   Click image for larger version
ID:	119169   Click image for larger version
renorealtors is offline
post #2 of 7 (permalink) Old 05-22-2019, 05:30 PM
Quoted: 349 Post(s)
Originally Posted by renorealtors View Post
Hi All.
This was just recently covered in another thread. If it is an aftermarket pan - that's your problem.
post #3 of 7 (permalink) Old 05-22-2019, 05:34 PM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
and aftermarket center link
and idler arm
and,,,,,
it looks like its time for some motormount lift plate spacers...
maybe a pair on each side....
watch your carb stud to hood clearance.................
BLK69JUDGE is online now
post #4 of 7 (permalink) Old 05-22-2019, 05:38 PM
Quoted: 349 Post(s)
and idler arm
and,,,,,
Yeah, I didn't want to go that far with suggestions, but it could be all of the above. Some guys will simply dimple the pan to take care of it - but not the best of fixes.
post #5 of 7 (permalink) Old 05-23-2019, 11:06 AM Thread Starter
Quoted: 13 Post(s)
Thank you guys for the ideas. My regular mechanic suggested removing the center link and he will gently bend it at each end. My body man was saying the rag joint was hitting the header and he could not steer it so he lifted the motor and blocked it so he could move it around. I have lowered it back down and the rag joint clears with an 1/8" so he was probably wrong and it was the pan hitting. I did see the other posts and just thought Canton would build a pan that would fit and I could have some wrong parts on it. I will do any and all the fixes you sent till it is up enough to clear. THANK YOU AGAIN.
post #6 of 7 (permalink) Old 05-24-2019, 04:45 PM
Quoted: 98 Post(s)
All due respect, you need to find another 'regular mechanic'. Bending a center link is completely out of the question. It's beyond jury-rigging to get the job done. Waaaay beyond. The issue is your aftermarket oil pan. Even with the stock pan, the clearance can be tight.
post #7 of 7 (permalink) Old 05-29-2019, 08:04 PM
I had the same problem with my 65 GTO that had an aftermarket oil pan. I fixed it by using motor mount spacers to raise the engine about 3/8"". That was several years ago and has been fine.
Taylor65Goat is online now
What's wrong with this picture? ibarbuckle 1964-1974 Tempest, Lemans & GTO General Discussion 4 03-31-2015 08:10 PM
whats wrong with this picture?? Geeza71 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 04-29-2013 06:42 PM
65 GTO Frame, Fuel, Brake Line Pics....Picture Heavy Thread... WideTrack 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 15 09-08-2012 06:45 PM
is it wrong....for a 67 lemans, to sport a 67 gto grill? virginiavenom 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 13 03-05-2011 04:58 PM
Picture of 2009 GTO (actual picture) IDBNVS2 2004-2006 GTO General Discussion 32 11-13-2006 10:17 AM
