Whats on your WINTER, "To Do" list? - Pontiac GTO Forum
 3Likes
post #1 of 17 (permalink) Old 11-27-2018, 07:17 PM Thread Starter
Quoted: 23 Post(s)
Living in the MotorCity it's a given that our driving season (if you keep your car out of most elements) is a bit limited so try not to take on any projects on the car that will involve it being off the road for more than a few rainy days and of course any must do fix. I look at the fall/winter as time for the "To Do List". so far mine is after topping off to 3/4 tank with Torco and putting it on rollers in the barn...
To Do:
Start once a week and run up to temp (165 thermo)
1.) rewire stereo and amp and stiffen mounts (done this weekend).
2.) Replace wooden dash insert with higher quality aluminum backed one.
3.) Purchase posi unit for the series 2 12 bolt A-body rear end i got a deal on a few years ago (need to have discussion on units and gearing, narrowing).
4.) Build and install said rear end.
5.) Install new boxed or round adjustable rear end components.
6.) Flush and change oil and trans fluid, check all others.
7.) Check ALL bolts when working on any area.
8.) Replace body to frame dampeners (least favorite)
9.) Install new correct RA exhaust manifold gaskets after burning the originals to the fiberglass on the dyno (got away with the multi use layered aluminum ones when i was in a hurry to get it back on the road but have a few exhaust leaks that popped up).
I'm sure ill be asking lots of questions i have probably asked in the past as my memory is for crap since falling 30' off a roof 3 years ago.
Fell free to add your List, i envy you guys that get to enjoy your cars 10-12 months a year.
Brian
Instg8ter is offline
post #2 of 17 (permalink) Old 11-27-2018, 10:25 PM
jsgoatman's Avatar
To do?? Make it through the Michigan winter!! Can't wait till spring! Happy Holidays!!!
jsgoatman is offline
post #3 of 17 (permalink) Old 11-28-2018, 02:46 AM
Cafr119's Avatar
Quoted: 38 Post(s)
I agree with both of you, I’m a Michigan native as well. Happy Holidays to all here on the forum as well, love watching and reading everyone’s builds, repairs and mods.
Cafr119 is offline
post #4 of 17 (permalink) Old 11-28-2018, 08:25 PM
Quoted: 79 Post(s)
I expect to finish my project car this winter and drive it in the spring. Took advantage of the warm sunny days to work on the top. Almost got it buttoned up but ran out of time. Will let it sit in the sun on Saturday so the fabric can relax enough to latch it down tight and then glue the side rail flaps.
Will begin assembling the engine after the top is done.
1968gto421, tiretread and T41Guy like this.
Shake-N-Bake is offline
post #5 of 17 (permalink) Old 11-29-2018, 08:13 PM
Quoted: 33 Post(s)
Being from MN I can relate to the frozen tundra! I have the front suspension tore down and am rebuilding the front with new parts.
tjs72goat is offline
post #6 of 17 (permalink) Old 11-29-2018, 09:39 PM
RMTZ67's Avatar
Quoted: 82 Post(s)
Almost got my engine complete. Hope it runs as good as it looks.Then on to 4 wheel disk brakes while the engine is out. Also got 2.5" exhaust ready as well. Can't wait for spring.
ID:	116519   Click image for larger version
ID:	116521   Click image for larger version
RMTZ67 is offline
post #7 of 17 (permalink) Old 11-30-2018, 05:39 AM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
Last season was the interior floor along with a factory vacuum trunk release,
since the hose ran under the carpet I figured a point up was in order.
Then late in the season was the top end on the '66.
Getting ready to overhaul the PS Res and Lines.
Then going to underside for a good bit of Re-freshening up.
Lots of road grime and wear and tear from 20+ years since resto.
ID:	116525   Click image for larger version
Name:	GLOVE BOX SUPPORT PROVISION 5.jpg
ID:	116527   Click image for larger version
Name:	OVERHAUL 3 (2).jpg
ID:	116529   Click image for larger version
Name:	OVERHAUL 14 (7).jpg
ID:	116531   Click image for larger version
Name:	OVERHAUL 24 (4).jpg
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #8 of 17 (permalink) Old 11-30-2018, 06:44 PM
Quoted: 119 Post(s)
Pulling the 383 out of the '61 Corvette and freshening it up. Also going to overhaul the ST-10 trans. Replace the upper control arm bushings in the '67 GTO. Install a new battery and adjust the advance curve in the '65 GTO.....and on and on!
post #9 of 17 (permalink) Old 12-01-2018, 03:40 AM
Cafr119's Avatar
Quoted: 38 Post(s)
Well, right now I’m currently cutting out the Michigan rusted cab corners and rockers on my 2001 GMC Sierra, deciding if I want to use the box I bought or have a flatbed installed ( hmmm ???? ) and installing a lil suspension lift as well, and hopefully getting back to restoring my 83 Honda Shadow that has been disassembled for some time now.
ID:	116645   Click image for larger version
ID:	116647   Click image for larger version
Cafr119 is offline
post #10 of 17 (permalink) Old 12-02-2018, 01:20 PM Thread Starter
Quoted: 23 Post(s)
Great reply's, goes to show with anything as old as our cars even after a restoration there will always be things that you need to do, and want to do. IMHO They are not meant to just sit there unless it's a low mileage numbers correct car, and then the only fun in that is looking at it and driving it on and off the trailer at shows. Good wrenching to all, spring will be here sooner than you think.
Whats your favorite type of "wax"? Surf City Garage Exterior Discussions 13 08-28-2015 09:27 AM
Whats in your "Garage"? ALKYGTO The Lounge 0 04-29-2015 10:52 AM
Add my goat to the "Dead GTO" list... Good 2 go 2004-2006 GTO General Discussion 38 11-25-2007 02:22 PM
Winter Tires: Dunlop Winter Sport M3s hsv Wheels and tires 7 11-09-2007 12:51 AM
Dyno numbers on your GTO...Stock or otherwise, List mods... hssaini 2004-2006 GTO General Discussion 17 07-22-2005 01:58 PM
