Will a 421 Tripower intake fit a 69 400? - Pontiac GTO Forum
post #1 of 16 (permalink) Old 08-10-2011, 03:23 AM Thread Starter
Hi from Germany
i own a 78 TransAm for myselfwith wrong engine, friend owns a 69 GTO
He has his engine broken and we search for a new. Now we have an offer, 69 400 Engine, without intake. The man that wants to sell the engine has also a TriPower Setup from a 62 421 (?)
Question 1 is: Will that intake fit the heads?
Question 2 is: Will the carbs feed the engine well when we use little bit more cam?
Question 3 is: If it fit, what HP we can expect?
VolkerGermany is offline
post #2 of 16 (permalink) Old 08-10-2011, 08:15 AM
jetstang's Avatar
Welcome!
The early intakes have an extra mounting bolt hole in the rear of the intake. I don't know if you can weld up the hole and use it or not, probably not.
Burning rubber since 1982!!
jetstang is offline
post #3 of 16 (permalink) Old 08-10-2011, 08:51 AM Thread Starter
Do you have a pic that shows the difference?
post #4 of 16 (permalink) Old 08-10-2011, 09:14 AM
Quoted: 102 Post(s)
A 1965 or 1966 tripower will bolt right on with no changes. A 1964 and earlier tripower is a different story, as stated above. It will only work if you use early '64 and earlier heads. You most likely have a '65-'66 unit, as they were more common. It should be ok.
post #5 of 16 (permalink) Old 08-10-2011, 09:40 AM Thread Starter
ok thank you
so it makes no sense to buy that setup exept to sell it here or on ebay i guess and take that win and invest in a set of heads, wight?
post #6 of 16 (permalink) Old 08-10-2011, 09:42 AM
Why would you buy heads?? Why not buy the right Tri-Power set up? (`65 and up)
post #7 of 16 (permalink) Old 08-10-2011, 09:51 AM Thread Starter
I donīt know the setup of the engine right now. We plan to convert the 400 to a 455, goal is 430HP+
And i have no idea yet how much the 68 heads will give me in difference between cast heads and TriPower or Aluminum heads and SingleCarb
post #8 of 16 (permalink) Old 08-10-2011, 10:10 AM
Use the search buttons, there has been alot of discussion on this subject in several threads.
post #9 of 16 (permalink) Old 08-10-2011, 10:37 AM
jetstang's Avatar
I don't think the sale of a tripower intake is going to pay for a $3000 set of heads. Tripowers work on Aluminum heads, and look really cool. There are plenty of threads on here about engine builds, and HP output. Torque is king with the Pontiac, but 455 should easilly push 430 HP without being too wild. You being in Germany, you can still get the high octane gas to run the high compression heads that we can't in America. Although it is over $10 a gallon..
jetstang is offline
post #10 of 16 (permalink) Old 08-10-2011, 11:58 AM Thread Starter
I tried the search-button... and there are a lot of treads... and i donīt know which one could that be for build a budget 455
tripower 455(71)HO vs my 69 400 EP Goat 2004-2006 GTO General Discussion 1 05-18-2011 04:21 PM
Intake Manifold Bolt Kits for a 64 tripower marks64 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 07-14-2009 04:28 PM
68 tripower intake wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 2 09-06-2005 03:41 PM
