Will Chevelle bushings fit a GTO? - Energy Suspension - Pontiac GTO Forum
post #1 of 8 (permalink) Old 10-23-2013, 12:17 PM Thread Starter
Orion88's Avatar
So I am trying to order new polygraphite bushings for my 1970 GTO from energysuspensionparts.com. They have very little listed for the 1970 GTO, but have tons of things listed for the 1970 Chevelle. As far as I know, all Buick, Chevy, Olds, and Pontiac A-bodies of the same year should have matching frames, and matching suspension components, correct? The only difference I am aware of is some have an oval bushing for the lower control arm and some have a round bushing. Am I mistaken? I was going to purchase new polygraphite body mounts (incl. hardware), front control arm bushings, sway bar bushings, sway bar end links, radiator isolators (big block), and rear coil spring isolators. The parts are all made by energy suspension, and correct me if I am wrong, but I don't see why the aftermarket polygraphite Chevelle bushings wouldn't be exactly the same as GTO bushings.
"You Gotta Have Fun When You're Little!!"
-Dick Schindler
Orion88 is offline
post #2 of 8 (permalink) Old 10-23-2013, 12:34 PM
Quoted: 105 Post(s)
They are the same. The oval lower A arm bushings are '66 up.
post #3 of 8 (permalink) Old 10-23-2013, 02:11 PM
Icefan71's Avatar
One of my front control arms on my 72 Lemans is from a Chevelle. Can't remember if it was from a 70 or 71. They should all be the same 66-72.
Icefan71 is offline
post #4 of 8 (permalink) Old 10-23-2013, 07:40 PM Thread Starter
Orion88's Avatar
Ok so the guy I'm dealing with at energysuspensionparts.com is dumber than a box of crap so I'm not ordering from him. Someone who has replaced their bushings with polyurethane who did you go with?? I don't need the hyperflex kit because I do not need rear control arm bushings, or tie rod/ball joint dust boots. I do need:
Body Mount bushings and hardware
Front control arm bushings - oval
Front sway bar bushings/mounts - 1-1/4" sway bar
Front sway bar end links
Rear upper coil spring isolators
Radiator Isolators
Had I ordered them from energysuspensionparts.com it would have cost $267.92.
I know it's more complicated cuz I don't need the kit but somewhere has to be able to put this order together.
-Dick Schindler
Orion88 is offline
post #5 of 8 (permalink) Old 10-24-2013, 06:24 PM
I used these guys and I am very happy with thier products - Welcome - Performance Suspension Technology
post #6 of 8 (permalink) Old 10-24-2013, 08:43 PM Thread Starter
Orion88's Avatar
I liked PST but they were a fair amount more expensive than other sites... About $50-100 more for the same bushings.
-Dick Schindler
Orion88 is offline
post #7 of 8 (permalink) Old 10-24-2013, 09:48 PM
Well I'll preface my little story here by saying "you get what you pay for".
I ran a stock sway bar on the front of my GTO for years with the supplied bushings and links I got with the PST kit with no problems. Upgraded to a 1 1/4 bar (which made a noticeable difference ) but split the Energy Suspension bushings I procured at the local Auto-zone or O'rielly's or wherever i got em.
Needless to say I called PST back up and got a new set from them. Yeah, they cost a little more but the money I spent on the ES kit was wasted so I spent that much more.
post #8 of 8 (permalink) Old 10-24-2013, 10:19 PM Thread Starter
Orion88's Avatar
Interesting. Any other disappointed ES customers out there?
-Dick Schindler
Orion88 is offline
will 69' 12 bolt chevelle rear end fit 66' tempest Instg8ter 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 13 12-31-2010 02:57 AM
Energy Suspension Bushings - on rear 04m6_ca Service, Maintenance and Technical Discussion 0 06-11-2005 11:15 PM
