Wiring Question - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-22-2017, 05:52 PM Thread Starter
alanmay0's Avatar
Wiring Question
I am in the process of putting my 67 GTO together after finally getting it back from the restoration place. My question is how do the wires from under the dash go through the firewall and into the engine compartment. I'm talking about the harness that goes to the fan blower, the main relay for the a/c the wires for the heater temperature. I can not find a place to put them through.
thank you in advance.
alan
alanmay0 is offline
post #2 of 5 (permalink) Old 10-22-2017, 06:17 PM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
The main AC harness on the '66&'67 enter the engine bay via the 2" hole/Grommet in the main Plenum.
I doo not know if the grommet is re-poped.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 5 (permalink) Old 10-22-2017, 10:17 PM Thread Starter
alanmay0's Avatar
Thanks, I purchased this grommet new from Ame's and it only came with three holes in it for the three vacuum lines, no other holes were available. Does this mean that I need to cut out a notch to run the harness through?? Two of the vacuum lines run to the ac vacuum valve just to the left of the yellow circle and the third runs to a vacuum port on the intake manifold. No forth hole.
Alan
alanmay0 is offline
post #4 of 5 (permalink) Old 10-23-2017, 04:45 AM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
Ames does not offer the correct grommet;
The OE will have 4 holes 2 small and 2 larger with a slice to feed the harness into it.
I'm unaware of anyone making the correct one. You may be able to modify that one?
post #5 of 5 (permalink) Old 10-23-2017, 08:25 AM Thread Starter
alanmay0's Avatar
thanks for all your help. I will modify the three hole one I have.
alan
Alan
alanmay0 is offline
Wiring Question? shelbee350 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 08-09-2012 06:46 PM
Wiring Question wvmtnman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 08-19-2011 09:42 PM
64 wiring question Help! homer43 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 10-27-2010 11:06 AM
68 wiring question Permages 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 05-31-2010 08:15 PM
wiring question denf221 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 04-28-2010 03:48 PM
