Wont start - Pontiac GTO Forum
post #1 of 15 (permalink) Old 04-04-2011, 10:45 PM Thread Starter
Wont start
Just installed a new camshaft, everything was working perfect, thanks to you guys. I took it out tonight to fill it up and put a few miles on it, drove it for about 10 miles, all the sudden it died. No stumbling, hesitations, nothing. It will turn over and all the lights work, just wont start. Acts like it is out of time, all opinions welcomed. Thanks
simmons68 is offline
post #2 of 15 (permalink) Old 04-05-2011, 05:55 AM
Have you checked your ignition coil? Ignition wire ok?
post #3 of 15 (permalink) Old 04-05-2011, 06:37 AM
Did you tighten the dist. after timing. (2) Do you have spark? (3) are you getting fuel to the carb? Answer these 3 questions first, so we know where you're at!!
Eric Animal is offline
post #4 of 15 (permalink) Old 04-05-2011, 11:57 AM
Quoted: 100 Post(s)
Stock distributor? Stock carburetion/fuel pump? Sounds like you lost ignition. I agree, check for spark. Your points could have closed up. Also, check the bulkhead connectors under the master cylinder on the firewall...make sure they're plugged in all the way. Probably not that, though--if it were you wouldn't have any power to the lights, etc.
post #5 of 15 (permalink) Old 04-05-2011, 03:17 PM Thread Starter
Wont start
Thanks for the quick replies. I am getting spark ( checked 1 plug and coil) Coil is brand new along with new plugs. The distributor was still tight and did not move. I have an HEI petronix ignitor that has been in the car for two years, I am getting plenty of fuel. Maybe the ignitor, is there a way to check it?
post #6 of 15 (permalink) Old 04-05-2011, 05:42 PM
Quoted: 100 Post(s)
If you are getting spark at the plugs, it's not the ignitor. If you are getting spark at the coil tower but not at the plugs, it's a burnt through rotor. If spark at the coil tower but not at the coil wire to dist. cap, then it's a burnt out coil wire. I would check for spark at number one plug, and check your base timing. It should spark at or near TDC on the crank pulley. You need fuel, ignition, and compression to run. And it all has to happen at the "right time".
post #7 of 15 (permalink) Old 04-05-2011, 06:41 PM
Are you getting too much fuel, stuck float....flooding? Not trying to be a wise azz, are you sure the "fuel" was gasoline and not diesel, contaminated with water, E85..... check a sample.......Eric
post #8 of 15 (permalink) Old 04-05-2011, 06:45 PM
Does it sound strange when it cranks.....possible timing chain issue???? I'm trying to think along the lines of "things you did just before it quit".....E
post #9 of 15 (permalink) Old 04-05-2011, 08:47 PM Thread Starter
wont start
Its an Edlebrock 750 carb that has always ran fine. Stock distributor, it sounds just fine when it cranks and will start for half a second then die. I only get gas from one store that has always had good gas, plus I run a can of Berryman b-12 in every tank. I let it set overnight, then tried it and the same thing happened. I checked the carb out and all was in order. I'm stuck
post #10 of 15 (permalink) Old 04-05-2011, 09:15 PM
ok, you have spark. are you pumping fuel? new cam install. did you install the fuel pump drive correctly? it must be installed off center. remove the fuel line and add a hose and see if you can pump gas into a container.
freethinker is offline
Help ? 71 lemans wont start, not even crank. ?? projectszero 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 01-05-2011 06:41 PM
Car Wont Start Help!!!!!!!!!!!! Vettekid1992 Intake and Exhaust Discussions 4 03-13-2010 11:30 PM
2004 GTO wont start laredo350 Service, Maintenance and Technical Discussion 1 11-29-2009 07:59 PM
car wont start 740tank Service, Maintenance and Technical Discussion 4 11-22-2009 01:48 AM
car wont start at all Musicmike927 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 10-30-2009 04:29 PM
