Wrong header panel - Pontiac GTO Forum
post #1 of 8 (permalink) Old 12-01-2009, 03:54 PM Thread Starter
MaL
MaL's Avatar
Send a message via AIM to MaL
Wrong header panel
I received my '66 GTO with a '67 LeMans/Tempest header panel (since it has the word "Pontiac" on it) and a '67 grille.
I want to revert all parts back to a '66 GTO.
My questions are-
Would this incorrect '67 header panel fit correctly on a '66 core mount and fit fine with the fenders if the years are different? Would '66 front fenders fit fine with a '67 header panel and grill?
I'm trying to figure out how many parts I will be replacing. Just the grill and header panel or the front fenders and core mount also?
other info-
Front fenders are a different color than the car so I don't think they are original.
There were missing bolts here and there during disassembly of the front.
MaL is offline
post #2 of 8 (permalink) Old 12-01-2009, 04:24 PM
whole assembly?
i'd have to look at a 66 header(doesnt the painted parts come down/across the bottom creating the opening?),,i MAY be a buyer for any front end `67 stuff,mine is complete but of course a crack here,split there
the fenders should be direct fit as will the radiator support?
hey!,i have a 72 flat rate manual! i was going to dump on eBay,i'll dig it out and check back later today,,hold it!,the fender#'s ARE going to be dif.,,the rocker trims would call for a dif part number(the holes are stamped dif),,i'll spec check the rad support at least=later
somewhere in oregon praying for some good gas,cool weather and a two car length jump on ya!
Hammer is offline
post #3 of 8 (permalink) Old 12-01-2009, 08:43 PM
67 Basket Case Restorer
Too Many Projects's Avatar
There is a small tab on the fender that meets the header. The 66 is shorter. If your fenders meet the panel fully and have a small indent for the headlight bezel, then the fenders are 67 also. The core supports and bumpers are the same for both years, so it doesn't matter if it was changed. It's possible someone changed out the whole front clip in the past.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #4 of 8 (permalink) Old 12-01-2009, 08:47 PM Thread Starter
MaL
MaL's Avatar
Here's the header panels side by side.
I'll be replacing the grill and panel.
TMP, thanks, I'll keep the core. I'll have to see about the fenders. The problem is the whole front is apart and the body is at the shop. I only have the rolling chassis and fenders in a shed.
If I took pictures of the fenders by themselves, could you ID them as '66 or '67?
MaL is offline
post #5 of 8 (permalink) Old 12-01-2009, 09:10 PM
Yes. Get a pic of the tab next to the headlight bucket where the header panel would meet it.
Mitch
1962 Impala SS
1938 Chev coupe
post #6 of 8 (permalink) Old 12-02-2009, 04:23 PM
Here ya go, MaL
Mitch
1962 Impala SS
1938 Chev coupe
post #7 of 8 (permalink) Old 12-05-2009, 03:09 PM Thread Starter
MaL
MaL's Avatar
TMP, excellent help! I took a pic of mine and it looks like '67 fenders.
Is the tell-tale sign the indent?
Please, confirm-
MaL is offline
post #8 of 8 (permalink) Old 12-05-2009, 04:58 PM
[QUOTE=MaL;206799]TMP, excellent help! I took a pic of mine and it looks like '67 fenders.
Please, confirm-
Yep, if you're interested in trading the left one for mine, shoot me a PM. My 66 is decent but needs the usual lower dog leg patch. I have a patch you can have with it too, but it's the one without the inner brace and is more work to make fit right. I can take a bunch of pics and send them to you.
PS, I think I acquired a right one too but would need to check and see what it looks like. I have a few fenders out in the shop and some of them are marginal.
Mitch
1962 Impala SS
1938 Chev coupe
1969 taillight panel? TehGTOfan89 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 16 10-27-2010 11:11 AM
2004 GTO Instrument Cluster Lens chucksgto Interior Discussions 9 01-24-2009 06:41 PM
67 gto header panel where are all the bolts? commodity1 1964-1974 Tempest, Lemans & GTO General Discussion 1 01-13-2008 11:17 AM
