Wussing on the vent - Pontiac GTO Forum
post #1 of 5 (permalink) Old 01-04-2010, 10:34 PM Thread Starter
MaL
MaL's Avatar
Send a message via AIM to MaL
Wussing on the vent
I've unscrewed-
The three screws on the door upper frame.
single screw on the vent to door outer panel
and the lower adjusting stud & nut at the bottom of the door
(the main window is completely removed)
The vent window will not budge!
Am I being a wuss and should put a bit more effort into yanking it out?
I've seen other Fisher '66 bodies that have a couple of additional bolts above the upper hinge, but these doors don't have those showing on the outside.
MaL is offline
post #2 of 5 (permalink) Old 01-04-2010, 10:36 PM
You have the main door window removed, right?
post #3 of 5 (permalink) Old 01-05-2010, 07:50 AM Thread Starter
MaL
MaL's Avatar
Yes, the main window is out.
MaL is offline
post #4 of 5 (permalink) Old 01-05-2010, 08:35 AM
MaL,
Is your car a hardtop or a post? I believe that drawing is for a 24207 car.
I've attached a couple pictures of the vent window and frame from a 24217 and circled the areas where I believe the screws are attached to the door;
ID:	6269   Click image for larger version
05GTO is offline
post #5 of 5 (permalink) Old 01-05-2010, 06:29 PM Thread Starter
MaL
MaL's Avatar
I've looked it over and may need a mirror to see inside, because externally there are no more screws or bolts.
Are these internal pieces that disassemble from inside?
MaL is offline
Need help. I need a/c vent temperatures. justin-branam 2004-2006 GTO General Discussion 3 06-20-2009 10:16 AM
Trunk Vent djdonte 2004-2006 GTO General Discussion 7 09-23-2007 11:48 AM
Vent Visors The_Bleek Exterior Discussions 3 05-01-2007 08:02 PM
Vent Odor GTOJon Service, Maintenance and Technical Discussion 5 07-18-2006 06:57 PM
Vent Window dylan44 Service, Maintenance and Technical Discussion 2 01-19-2005 05:45 PM
