10 Bolt 8.5in. 3.08 HELP - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-24-2014, 10:16 PM Thread Starter
mtman's Avatar
Hi, My 74 came with 10 bolt 8.5in. 3.08 gears. Now sitting up on blocks I turn one wheel and the other wheel does nothing and finally starts to turn. So I thought it was trashed, so I pulled the cover off to see what I could see. Well the oil was a little dirty but not muddy and no chunks of metal. All the gears look OK, so turning the wheel and watching inside it seems to turn ok but still waiting for other wheel to catch up. the ring gears # 2 GM 3804028 13 40 11 73 the 11 is questionable. Any help with what's going on in there ? Thanks Mike
mtman is offline
post #2 of 5 (permalink) Old 10-24-2014, 11:01 PM
Quoted: 11 Post(s)
I believe it indicates;
13 = pinion gears #
40 = ring gears #
40 divided by 13 = 3.07692303
11 = November
73 = 1973
Possible a build date,
But I could be wrong!
05GTO is online now
post #3 of 5 (permalink) Old 10-25-2014, 09:43 PM
[B]what it means to me is that you have a open type rear diff. as oposed to a limited slip rear diff.3.08 gears were designed for hyway fuel economy, and not for quick accelaration, when one wheel is rotated by hand, the other wheel rotates in the oposite direction , as long as diff doesn't whine or clunk when driving all is normal. Hope that answers some of your questions.
torrid red sap is offline
post #4 of 5 (permalink) Old 10-26-2014, 12:23 PM
chuckha62's Avatar
Quoted: 18 Post(s)
Sounds like it is working as intended for an open differential.
chuckha62 is offline
post #5 of 5 (permalink) Old 10-26-2014, 11:36 PM Thread Starter
mtman's Avatar
Thanks Gang, Looks like a total rebuild. Just need to decide the TH400, or pickup a700R4 Need to start a new thread about trans. rear tire size. Thanks Mike
mtman is offline
1964 12 bolt to 10 bolt remy30006 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 08-06-2013 11:53 PM
12 bolt JLuger 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 5 09-09-2012 05:18 PM
Is the 10 Bolt 8.2 BOP Carrier the same as Chevy 10 Bolt? mighty454 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 04-21-2010 04:30 PM
10 Bolt Versus 12 Bolt Rear Axle take5 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 09-28-2009 04:45 PM
69 GTO 10 bolt non-posi convert to 12 bolt posi AzStateFan 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 09-12-2009 05:34 PM
