10 bolt diff gear swap - Pontiac GTO Forum
post #1 of 15 (permalink) Old 04-02-2014, 11:03 AM Thread Starter
Hey guys:
I'm going to swap out a ring and pinion (used-the one going in is a safety trac as well as a ratio I like better). I'm guessing that I can't count on the pinion shims being the same, so would the best thing to do be to remove both rear pinion bearings and start with the amount of shims that were in there on the pinion that I'm putting in? I have a new bearing and shim kit to work with. I am also curious about the pinion shimming when it comes to making changes: does it involve pressing off/on the bearing with each change of shims? My book references some tool that checks the depth necessary for choosing total shim thickness but it's nothing like I've ever seen before. I'm OK with adjusting the side position of the ring gear, but obviously that comes last. Anywhere I can get an assembly instruction sheet in plain old English?
Chemnick
chemnick is offline
post #2 of 15 (permalink) Old 04-02-2014, 01:09 PM
Quoted: 119 Post(s)
Chem, are you aware of the 3 different carriers that work with all of the ratios, and that they are not interchangeable? If you are, and have the right carrier to use, a factory manual will give you the information you will need to know. That or the MOTORS manual for your year. Setting up these rear ends is not a cake-walk. You need experience and technique to pull it off and end up with a quiet rear end. I would recommend having a differential shop do the work on the set-up.
post #3 of 15 (permalink) Old 04-02-2014, 02:10 PM
I'm with Mr geeteeohguy on this... if you have not done this before, don't do yours first. And if you still want to cause it looks simple, call an expert first. I think you will be taking it a shop soon after. I have received credit for this one at the School of Hard Knocks. Best wishes. Matt
Matthew is offline
post #4 of 15 (permalink) Old 04-02-2014, 07:42 PM Thread Starter
Thanks for the replies. I was under the impression that if the housings were the same (and the casting numbers, too) that they would interchange pinion and carriers. Unfortunately, I have just pulled the ring and pinion out of the donor a few days ago. To be specific: the diff in the rolling frame now is an open 3.23 (think I have that right) and the donor is a 2.78 safety trac two pinion side gears (again, I think that's correct). So now the issue is if these two gear sets are interchangeable. BTW, why you ask? Well the diff in the rolling chassis I bought was all stripped, cleaned and repainted and the donor differential was fine inside but ugly outside. All I did check was to see that the center casting number was the same on both. The body shop is just about ready for the frame back and at least all I've done so far to the one in the chassis is pull the cover. If it were the case that I needed to use the donor housing, I would assume that if it were reassembled back as it was and showed good backlash and gear contact life would be good, although I do have that bearing and shim kit. Also, I do have an open 3.08 gear set upstairs in the garage. Just the carrier, ring and pinion. Quote from Laurel & Hardy: "Here's another nice mess I've gotten me into."
chemnick is offline
post #5 of 15 (permalink) Old 04-02-2014, 08:11 PM
Quoted: 16 Post(s)
I you haven't done this before I would defer to a professional.
When I set up ring and pinions I have a set of "trial" bearings that have the inner races opened up slightly so they are not a press fit but rather a slip fit. I set everything up and get my pattern then disassemble and press on the new bearings.
post #6 of 15 (permalink) Old 04-02-2014, 08:11 PM
Quoted: 23 Post(s)
if not, i might be interested in the 2:78...
Instg8ter is offline
post #7 of 15 (permalink) Old 04-02-2014, 08:27 PM
Quoted: 16 Post(s)
Oohh, a set of "digger" gears . Quite a step up from those 2:56's....
What you really need is some 3:55's.....just sayin'.......
post #8 of 15 (permalink) Old 04-02-2014, 09:20 PM
Quoted: 23 Post(s)
What can i say, i'm into 16-18 MPG with 462 cubes...built for comfort not for speed, well ok, a little speed. Keep staring at the 12-bolt on the shop floor, have the 3:55 gear just need a posi carrier as it's got a racing spool in it now. Got any Cheby parts laying around? I can say i am glad GeeTee talked me into keeping the salt flat gear until i got some seat time in it. I may not get light to light the fastest but still plenty of power on tap down low, and when she makes third gear is still pulling like a train and just starting to breathe. Would really like to be 3:08 - 3:23, think that would be best of both worlds with the 3 speed auto.
post #9 of 15 (permalink) Old 04-03-2014, 01:26 PM
Quoted: 119 Post(s)
Chemnick: 2.56 and 2.78 gears use the same carrier. 2.93, 3.08, and 3.23 use another carrier. 3.36, 3.55, 3.90, 4.33 use yet another. You can not install 3.08 gears on a 2.78 carrier. What are you trying to accomplish here? The cheapest way to re-gear an 8.2 ten bolt is to simply buy a complete, drum to drum unit and bolt it in. The factory set up in the gears never seems to go bad, and you'll be good to go in a single day.
post #10 of 15 (permalink) Old 04-04-2014, 10:30 AM
chuckha62's Avatar
Quoted: 18 Post(s)
^^^^^Sage advice here! Of course you can go through all trials and tribulations and learn a bunch in the process, but when it's all said and done, you're going to be miles (and $$$) ahead just getting a complete rear end set up as you want it.
chuckha62 is offline
69 12 bolt chevy diff into 67 gto 4 speed mbspeed 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 7 01-26-2014 05:27 AM
8.2 10 bolt gear code location danthepontiacman 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 03-07-2012 08:24 PM
12 bolt swap problems? Pontiachris 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 01-05-2010 12:45 AM
