12 bolt - Pontiac GTO Forum
post #1 of 6 (permalink) Old 09-08-2012, 01:16 PM Thread Starter
12 bolt
New member here great site. I just picked up a 68 goat replacing the 66 I owned 25 years ago. The car is a one family owed but unfortunatly the son of the orginal purchaser doen't have much info on the car. One of my questions is it has a 12 bolt rear not posi but I believe limited slip. From what I've read the 68's only came with a 10 bolt is that right? I have the original window sticker and it lists a Optional Saf-T-Track diff for $42 dollars would that be the 12 Bolt?
John
JLuger is offline
post #2 of 6 (permalink) Old 09-08-2012, 06:01 PM
Quoted: 11 Post(s)
Welcome to the forum, Pontiac only used a 12 bolt type-c rear end starting in 1970 and it was available only with a 455 engine.
05GTO is online now
post #3 of 6 (permalink) Old 09-08-2012, 06:22 PM Thread Starter
Thanks Randy, I guess I have some detective work to do.
John
JLuger is offline
post #4 of 6 (permalink) Old 09-08-2012, 09:26 PM
Quoted: 16 Post(s)
Make sure it's a Chevy 12 bolt also (should have two cover bolts at the bottom) as opposed to an Old's "12" bolt (which is actually a "10 bolt"). Two different animals with the C type being much more desireable. The "12 bolt" designation is actually in reference to the ring gear bolts, not the cover bolts.
post #5 of 6 (permalink) Old 09-09-2012, 04:09 PM Thread Starter
Would this be a Chevy?
Name:	IMG_1904 (1024x768).jpg
JLuger is offline
post #6 of 6 (permalink) Old 09-09-2012, 05:18 PM
Quoted: 16 Post(s)
That looks to be the Chevy 12 bolt. I was mistaken earlier in that both the type O and type C 12 bolts have two bolts at the bottom. The Chevy version though has the "eyebrow" on the cover while the Oldsmobile is typically smooth. The only real way to absolutely determine if it is a Chevy would be to pull the cover and count the bolts on the ring gear. Chevy also has C-clip axle retention and Olds is bolt in.
AUS 9 bolt danfigg Drive train, suspension, alignment and brakes. 1 08-21-2012 08:30 PM
12 bolt billw 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 06-06-2011 06:23 PM
Is the 10 Bolt 8.2 BOP Carrier the same as Chevy 10 Bolt? mighty454 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 04-21-2010 04:30 PM
10 Bolt Versus 12 Bolt Rear Axle take5 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 09-28-2009 04:45 PM
69 GTO 10 bolt non-posi convert to 12 bolt posi AzStateFan 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 09-12-2009 05:34 PM
