12 bolt rear - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-08-2018, 05:38 PM Thread Starter
12 bolt rear
is a 65-66 chevelle 12 bolt rear a direct bolt in on a 1965 GTO? any alterations to driveshaft? spring locations? or anything else. I know they both used the narrow rear. I have the stock GTO 10 bolt rear in my car with 3:55 gears. the engine I will be using is just shy of 500 HP. thanks for any info. pinion head.
army6741 is offline
post #2 of 3 (permalink) Old 10-10-2018, 05:02 PM
Quoted: 117 Post(s)
PinionHead is the guru on this one, but in my knowledge, the '65-'66 Chevelle 12 bolt is no stronger than the original 8.2 Pontiac 10 bolt. In fact, it may be weaker. The later 8.5 10 bolt is a stronger unit. For 500HP, I would be looking at a Ford 9 inch for sure.
post #3 of 3 (permalink) Old 10-11-2018, 11:43 AM
1968gto421's Avatar
Quoted: 72 Post(s)
Having had a 9" Ford in a Studebaker, I can verify they are super strong and easy to change ring and pinon gears having a removable center section. Just find one the right width (or have one narrowed) and have brackets for your suspension arms welded on.
Many of the guys on the PY forum - Pontiac - Street - PY Online Forums - use the Moser 12 bolt rears and Moser 9" Ford rears. These are ready to bolt in and will handle far more than 500 hp. Here are some links:
12 BOLT MUSCLE PAK - Moser Engineering
9" HD STAMPED MUSCLEPAK - Moser Engineering
Hope this is of some help.
1968gto421 is online now
10 bolt vs 12 bolt pcolenutt 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 08-23-2013 05:44 AM
1964 12 bolt to 10 bolt remy30006 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 08-06-2013 10:53 PM
10 Bolt Versus 12 Bolt Rear Axle take5 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 09-28-2009 03:45 PM
69 GTO 10 bolt non-posi convert to 12 bolt posi AzStateFan 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 09-12-2009 04:34 PM
12 Bolt Rear End? dbuchholtz Drive train, suspension, alignment and brakes. 2 01-30-2009 09:00 PM
