12 bolt type "C" 70 GTO w/455 - Pontiac GTO Forum
post #1 of 6 (permalink) Old 08-13-2013, 04:31 PM Thread Starter
Iraq 69's Avatar
Hey All,
I have a 1970 GTO with the 455. The build sheet shows a change and I was told that the change note was for the line workers to install a type 'c' chevy 12 bolt. Is that like a Chevelle 12 bolt? Can someone educate me on this issue?
I am new to the GTO scene and need all the help I can get.
Thanks,
Marc
Marc
US Army Ret
MSG
OIF Feb 04-Jan 05
1970 GTO 455 HO
Iraq 69 is offline
post #2 of 6 (permalink) Old 08-13-2013, 06:07 PM
Quoted: 23 Post(s)
yes it's the same thing...455 cars were upgraded to 12 bolts
Instg8ter is offline
post #3 of 6 (permalink) Old 08-13-2013, 06:40 PM Thread Starter
Iraq 69's Avatar
Thanks,
Does that mean that I buy Chevy parts for the diff? Like a powertrax?
Does it still have the C clips?
Thanks,
Marc
Marc
US Army Ret
MSG
OIF Feb 04-Jan 05
1970 GTO 455 HO
Iraq 69 is offline
post #4 of 6 (permalink) Old 08-13-2013, 08:10 PM
Quoted: 16 Post(s)
Yeah, Chevy parts but....what are your ultimate intentions for the car if i may ask?
With a mild 455 and street tires the factory rear should be fine. If the dragstrip, high hp and slicks are your ultimate intention then yes, the c-clips issue will have to be addressed. To me the weakest link on these rears is the fact that they were engineered to use the axle shaft itself as the inner race for the outer axle bearing along with the c-clip retention.
There are several solutions to this but they require altering the axle housing itself so if it is the original you may want to set it aside and put another 12 bolt, 9" Ford or Dana in its place.
And...I haven't mentioned it yet Marc but thanks for your service to our country.
post #5 of 6 (permalink) Old 08-13-2013, 10:17 PM
You really have several options. Some C clip eliminators aren't suited for street use if they employ ball bearings, as these don't like side loading like you encountered when cornering. There are tapered roller type bearing eliminators that are better suited and street friendly. After-market axles are an option as well. Some are stronger, not tapered, and, made of better materials. They still use the "C" clips but are suitable for higher output engines, and require no modifications. Moser is one such supplier.
JustAl is offline
post #6 of 6 (permalink) Old 08-14-2013, 06:54 PM Thread Starter
Iraq 69's Avatar
Hey Guys,
Thanks for the help...Alkygto, your welcome.
My intentions for the car is to have a great cruiser. No racing, just making tire smoke once in a while. I do want to install a power-trax so I have 2 black marks on the street instead of 1.
It has 3:07 gears and I intend to stay with those till the trans needs work. Then I'll go with more gears and an OD auto trans.
Thanks,
Marc
Marc
US Army Ret
MSG
OIF Feb 04-Jan 05
1970 GTO 455 HO
Iraq 69 is offline
"New" 455 HO leeklm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 10-15-2012 10:54 PM
Need help '66 gto "6 bolt pulley" a/c add on take5 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 08-10-2010 07:33 PM
"bolt main" question dustyminpin 2004-2006 GTO General Discussion 2 05-19-2009 02:34 PM
Spare "tire"..better check it. "my lucky day" JWCACE Wheels and tires 0 05-17-2006 10:32 AM
