1964 GTO TH400 interchange ? - Pontiac GTO Forum
post #1 of 1 (permalink) Old 11-01-2016, 12:14 PM Thread Starter
Hello all, I'm new to this forum and am trying to help out a friend that inherited a 64 GTO from his father in law who was supposedly the original owner here in So. Cal.
From what I was able to decode, the 389 block (D 16 4) and heads are original to the car with a 4 E date on the trim tag.
The problem is that the original transmission is long gone and was allegedly lost at a rebuilder that closed his doors many years ago. My friend wants to put in a TH400 and we don't know what exactly will drop in with the minimum amount of modifications.
The 389 block is original with the bottom mounted starter. We want to use a Pontiac 400 and have a contact with a 1969 GTO 400 transmission.
So, would this transmission drop in with only a change in the flex plate, yoke, crossmember, maybe shortened driveshaft?
Any help is greatly appreciated!
John
sci-flyer is offline
67 GTO TH400 data tag drburns 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 9 05-23-2016 07:41 PM
64 GTO/65 Skylark Frame Interchange? Al T 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 06-28-2012 06:36 PM
65 GTO frame interchange mrdon50 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 11-03-2011 01:47 PM
1969 GTO interchange? xoman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 03-22-2010 09:27 PM
Firebird/ GTO interchange goatkid77 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 09-13-2009 02:49 PM
