1964 lemans- Help on rear sway bar - Pontiac GTO Forum
post #1 of 10 (permalink) Old 06-23-2012, 10:14 AM Thread Starter
What is the best an reasonably priced rear sway bar to buy for my 1964 lemans coupe? Car didn't come with one. Hopfully no drilling. Any help with this and better sway control handling. I have installed new coil springs and KYB shocks all around. Thanks.
utidad is offline
post #2 of 10 (permalink) Old 06-23-2012, 11:16 AM
Quoted: 119 Post(s)
Depends on what is considered reasonable these days. Rear sway bars require different or beefed up lower control arms to take the load ($$$ ), and these are drilled to accommodate the sway bar mounts. I have an old Aadco (sp?) bar on the rear of my '65 that installs with plates to the bottom of the arms, not the side. This still required drilling. Figure on spending upwards of $500 for the whole set up, or shop used like I did. I got a factory rear bar for my '67 for $40 at a swap meet, and found the correct arms for $50 used, needing new bushings. You CAN use the old arms if you install the stiffening kit available from the vendors, or if you fab up a couple of sleeves. Depends on how handy you are!
post #3 of 10 (permalink) Old 06-23-2012, 05:53 PM
I'm running the Spohn pro-touring sway bar. No control arm mods needed because it doesn't mount to the arms. I like it a lot.
post #4 of 10 (permalink) Old 06-23-2012, 07:07 PM
chuckha62's Avatar
Quoted: 18 Post(s)
Ames sells a kit complete with boxed lower arms and all bolts for $279.
chuckha62 is offline
post #5 of 10 (permalink) Old 06-24-2012, 08:34 AM Thread Starter
Thanks Guys.
utidad is offline
post #6 of 10 (permalink) Old 06-24-2012, 09:34 AM
sway bars are like disk brakes, waaay over rated!
post #7 of 10 (permalink) Old 06-24-2012, 12:15 PM
chuckha62's Avatar
Quoted: 18 Post(s)
You really think so? The difference in roll was very noticeable when I put the rear bar on my '67.
I was fortunate in that I was given a set of boxed control arms when I bought my car. All I had to do was get the bar and shims.
post #8 of 10 (permalink) Old 06-24-2012, 12:24 PM
Quoted: 119 Post(s)
$279 is pretty cheap for the whole set-up, IMO. Very reasonable. I thought it was about twice that. I am ignorant of the Spohn bar.....How does that mount/work?? In my personal experience with these cars, rear sway bars make them corner much better and flatter, as long as the front bar is upgraded too, in conjunction with installing the rear bar. You don not want a big heavy rear bar and a stock front bar. I have also experienced a harsher ride quality with rear sway bar equipped cars. It's a trade off.
post #9 of 10 (permalink) Old 06-26-2012, 10:16 PM
If you are wanting better handling, replace the front bar (7/8") with one from a big block Monte Carlo or Grand Prix, up to 1972. They are 1 1/8". Beefy. You need to upgrade your end links and bushing brackets, too. Not tough to do, but do it before the bar tears the bolts out of the frame.
The hottest places in hell are reserved for those who in times of great moral crises maintain their neutrality.
-Dante Alighieri
Knuckledragger is offline
post #10 of 10 (permalink) Old 06-27-2012, 09:16 PM
The bar itself clamps to the rear axle housing. There are adjustable end links on it that tie the each end of the bar to the rear crossmember. One nice thing about this arrangment is that if desired you can dial a little pre-load into one side of the bar to help the car launch straight at the track.
Here's a picture of mine...
And a close up of the end links and crossmember mount.
Spohn says the end link brackets have to be welded to the crossmember, but as you can see, I bolted mine and they're plenty strong.
74 GTO rear sway bar jdesk 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 07-27-2011 08:39 PM
Want to install rear sway bar on 64 lemans utidad 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 7 04-17-2011 12:09 AM
? Installing Rear Sway Bar starabby 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 01-27-2011 08:16 PM
Rear Sway Bar CTCarGuy 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 11-17-2009 05:24 PM
SLP Rear Sway Bar Install ronaldvetteron Service, Maintenance and Technical Discussion 9 06-02-2005 11:25 AM
