1965 GTO Frame Swap - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-03-2016, 04:52 PM Thread Starter
Send a message via AIM to rwltcowboy
1965 GTO Frame Swap
Hey Guys, I just purchased a running/driving 65 GTO 2 door sedan that needs restoration. I figured that I could drive as is for now, but be building a nice chassis for it on the side, and when the time is right pull the body off the current frame, do the body work and then set back onto the newly built chassis. So here is my question.....which other GM A-Body frames will interchange? I have a friend willing to donate the frame from either a 65 Chevelle SS or a 66 El Camino. Needing to know what will work with the least amount of modifications. Thanks for any help y'all can offer.
rwltcowboy is offline
post #2 of 4 (permalink) Old 06-03-2016, 06:19 PM
stich's Avatar
Chevelle is shorter by several inches. El Camino is the right size. As a bonus, it's a boxed frame so works for my convertible as well. That's what I'm getting for my car.
stich is online now
post #3 of 4 (permalink) Old 06-06-2016, 05:39 PM
Have pulled literally tons of A body frames, both for very picky restorers and for several late model circle track factorys. If shopping original convert frames for an early Pontiac A body, there are a few small detailing differences between a '64 and a '65 and a '66. Also if sourcing for a LeMans or GTO, you don't want to get one that came out of a '66 or '67 Olds Cutlass of 442. The Olds version has different width of front frame horns, due to Olds going to a cross flow radiator, 2 years before other GM A body's. Last thing to note, '67 A body frames have smaller rear spring pockets in the rear frame crossmember and accept the tapered top style '67 and later rear coil springs.
post #4 of 4 (permalink) Old 06-09-2016, 12:58 PM Thread Starter
Thanks for the info
Frame swap on 66 GTO convertible jeb77 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 02-27-2015 04:28 PM
1965 GTO convertible frame replacement RGTO 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 6 02-03-2015 03:04 PM
frame swap mikey9743 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 5 10-12-2013 06:55 AM
1965 GTO frame Margey 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 22 09-26-2011 08:51 PM
69 gto frame swap pontiacman63383 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 01-08-2011 08:24 PM
