1965 GTO rear end - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-09-2014, 11:11 AM Thread Starter
1965 GTO rear end
I just bought a 1965 GTO w/ an automatic trans it has 3:23 gears in the rear end. It's a posi traction. what gear weight do I use. I have the GM addtive. I have been told to use 80W90. Is that correct ? Thanks Does anyone know ?
Last edited by johns1965gto; 09-09-2014 at 02:28 PM. Reason: just wanted to ad a comment
johns1965gto is offline
post #2 of 3 (permalink) Old 09-10-2014, 01:19 PM
Quoted: 119 Post(s)
Yes. You can't get straight 90W anymore. You can actually get 75/90 or 80/90 that's for limited slip rear ends. Or you can ad the GM additive to any gear oil. Either way, it will be fine. 3.23 is the perfect gear ratio for these cars, and was standard in 1965.
post #3 of 3 (permalink) Old 09-11-2014, 09:21 AM Thread Starter
Thanks for your help... I'm sure I'll be asking more questions...
1965 gto convrtible rear seats ucaddoc 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 08-09-2014 08:35 AM
How do I fix rust around rear window of 1965 GTO dlloyd Exterior Discussions 2 08-05-2012 09:03 PM
64 GTO rear end khinton 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 03-24-2012 11:24 AM
67 GTO no rear end GTO_KID 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 05-10-2008 01:58 PM
