1966 6.4 389 front and rear spring options - Pontiac GTO Forum
 1Likes
post #1 of 13 (permalink) Old 07-01-2012, 09:06 AM Thread Starter
Guys,
For my 66 GTO I would like to restore stock ride height at an affordable price. Would you know what part numbers are recommended for this? Thought about airbags but I rather go with pure springs. Why is it that whenever you lookup rear springs for the 66 they only sell fronts? If you go 67 than you get more options.
Thx
louie3888 is offline
post #2 of 13 (permalink) Old 07-01-2012, 09:55 AM
Louie, Check with OPGI or PY, or AMES....if you want made to order springs, try EATON SPRING. Eric
Eric Animal is offline
post #3 of 13 (permalink) Old 07-01-2012, 11:46 AM Thread Starter
Thx. Which is PY?
post #4 of 13 (permalink) Old 07-02-2012, 12:58 PM
Joe C2 C5's Avatar
If you use PY or Ames you will get generally Moog generic springs for your application which means they fit all A body GM cars. If you go with Eaton or Custom Spring Specialties you can get exactly the specs the factory used or even modify from that point. Most people don't like the stock rear height ( which is low) and want a little more lift. The Custom guys can dial in whatever you want. When I got rear springs for my '66 I was able to talk with an engineer from Custom Spring and he told me Pontiac original springs were really soft so we went with a 15% increase in stiffness as well as a 1" increase in height (tail doesn't drag now) to get exactly what I wanted. There is a cost for this but not excessive and I felt worth it. Good luck in your choice.
Crusha likes this.
Joe C2 C5 is offline
post #5 of 13 (permalink) Old 07-02-2012, 07:01 PM
rickm's Avatar
Quoted: 5 Post(s)
convertible rear springs on a coupe or hardtop will give your car a real nice stance..rickm.
rickm is offline
post #6 of 13 (permalink) Old 07-02-2012, 07:17 PM
leeklm's Avatar
Similar to my experience... Ordered the "convertible" rear springs from AMES, which still sit plenty low. Ordered the front springs from Summit (Moog), which sit high if anything, but I actually need that height to get clearance on my 225/70/15 front tires. Could also be why my rear looks low... Ended up spending another $80 on rear air bags, which I like, and of course now can set the rear height based on load, etc.
leeklm is offline
post #7 of 13 (permalink) Old 07-03-2012, 07:10 AM
rickm's Avatar
Quoted: 5 Post(s)
hey, roughly how much height adjustment do you get out of a set of airlift bags? the convertible rear springs worked great on my '65 coupe. im also using monroe load leveler rear shocks, maybe they help some too. rickm.
rickm is offline
post #8 of 13 (permalink) Old 07-04-2012, 12:50 AM
chuckha62's Avatar
Quoted: 18 Post(s)
I bought Lemans wagon springs for the rear of my '67 from Rock Auto and they were inexpensive (something like $65 or $70 for the pair). They gave me an inch of additional height in the rear, which is what I was looking for.
They carry Moog, AC Delco, and Raybestos
Check 'em out at rockauto.com
chuckha62 is offline
post #9 of 13 (permalink) Old 07-06-2012, 07:51 PM
leeklm's Avatar
With only 15 pounds of air, I raised the back at least an inch or more. I have not yet attempted more, but my guess is 2-3 inches if I maxed the air pressure on the springs.n It is actually a little high now, so I am going down to about 10 pounds of air.
leeklm is offline
post #10 of 13 (permalink) Old 07-06-2012, 08:04 PM
ppurfield001's Avatar
Originally Posted by louie3888 View Post
Guys,
Thx
I recommend a god set of coil-over shocks.
ppurfield001 is offline
front coil spring installation Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 10-26-2010 08:54 AM
Need New Rear Spring Suggestions!!!!!!!!!!!!! Vettekid1992 Drive train, suspension, alignment and brakes. 10 03-01-2010 12:00 PM
rear spring specs danfigg Drive train, suspension, alignment and brakes. 0 10-04-2009 04:10 AM
Front Bumper/Cover Options HELP!! XV Scott Exterior Discussions 2 07-17-2006 09:09 PM
