1966 Lemans Core Support = NEED HELP? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 10-08-2016, 11:45 AM Thread Starter
Hey Guys,
Just started wrapping up the front end of my 1966 Lemans restoration. I'm about to mount the core support with the new bushing kit I bought from OPGI.
Here's the deal.... I took a ton of pics during disassembly and always reference them when putting the car back together. BUT, the pics I took of the core support bushings and bolts doesn't make sense. A previous owner must have done a semi-restoration and installed them in this sequence.
(Top to Bottom)
1. Washer
2. Thick metal shim
3. Core Support
4. Thick Bushing
5. Washer
6. Thin Bushing
7. Frame
8. Two Washers
9. Nut
Isn't their supposed to be a bushing between the frame and the core support, then a bushing on top of the core support, then the washer?
I attached two pics of the old installation before I took it apart and one pic of the new core support parts.
I reference every restoration book I have and I can't find the installation sequence I need to follow.
ANY HELP WILL BE GREATLY APPRECIATED! Thanks guys.
=KB=
Name:	Core Support 1.jpg
ID:	81305   Click image for larger version
Name:	Core Support 2.jpg
ID:	81313   Click image for larger version
Name:	Core Support 3.jpg
2009 Pontiac G8 GT (Daily Driver)
1966 Lemans Restoration (in Progress)
G8assassin is offline
post #2 of 7 (permalink) Old 10-08-2016, 12:14 PM
Quoted: 390 Post(s)
Deleted my answer/guess as a more correct reply with diagram was posted.
I also found this searching through the forums, "the bolt with washer comes from underneath and then a washer goes on the frame. Next the bushing with the sleeve and then the core support on that. Then the open bushing and another washer and nut."
PontiacJim is online now
post #3 of 7 (permalink) Old 10-08-2016, 01:49 PM Thread Starter
Hey Pontiac Jim! Thanks for the advice.
Only issue I see is that if I only use the one bushing between the frame rail and core support, it's not wide enough to fill the gap. If you look at the attached pic, it might explain it better.
The two core support tabs hit the frame rail so the bracket won't rest on the bushing.
Let me know if this makes sense and if anyone else has any ideas.
=KB=
PS... I've attached before and after pics to show you why I want to get this done. So close to wrapping up the front end and firing this thing up again!
Name:	core support bushing gap.jpg
ID:	81337   Click image for larger version
Name:	Engine Before.jpeg
ID:	81345   Click image for larger version
Name:	Engine After.jpg
post #4 of 7 (permalink) Old 10-08-2016, 02:52 PM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
See VIEW A for correct support bushing and shim layout.
Bolt comes up from underside and the OE setup used a Flat Nut Retaining tab to hold it in place.
You will also note the OE bushings used were square and most of the newer replacements are mainly round.
However if you wish to match the correct style,
just search the Buick/Olds suppliers as they offer the square bushing kits.
Also know that the amount of shims needed under the bushing will differ car to car, so it may take a few attempts to get the lines and gaps to an acceptable point. This may be the reason for the double bushings?
Have you confirmed the frame horns are within spec?
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #5 of 7 (permalink) Old 10-08-2016, 03:06 PM Thread Starter
Thanks GTOjunior!
Reference 'A' is exactly what I was looking for. I didn't know that I can shim under the bushing that goes on top of the frame rail. This makes more sense now. I have the round bushings which is ok with me. This isn't a concourse restoration as you can see by the pics of me adding coilovers, Tubular A-arms etc.
No... I didn't confirm the frame horns are in spec. To be honest, I'm not sure how to do that. This is my first restoration so it looks like I need to do some research on this topic.
=KB=
post #6 of 7 (permalink) Old 10-08-2016, 03:39 PM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
Glad to help.
Below is the Crash Sheet showing frame specs/measurements.
With car on a good level surface you can at least check to see if anything is way out of spec.
You can go old school and use string lines or if you have access to newer laser levels that works too.
post #7 of 7 (permalink) Old 10-08-2016, 04:21 PM Thread Starter
Thanks for the crash sheet. Just added it to my restoration folder for future reference.
Happy to report the core support is on, radiator is in and shroud is bolted up. All is good in restoration land!
=KB=
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
1966 A/C core support Tony Arnold 1964-1974 Tempest, Lemans & GTO General Discussion 5 05-08-2014 04:30 PM
1966 GTO A/C core support 2trower 1964-1974 Tempest, Lemans & GTO General Discussion 2 09-17-2012 04:23 PM
1966 core support hardware 1966Dave 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 08-15-2009 08:56 PM
