1966 Pontiac GTO - Transmission vaccum line placement - Pontiac GTO Forum
post #1 of 6 (permalink) Old 07-03-2014, 10:48 PM Thread Starter
I just put in a new edelbrock intake manifold and holley carburetor. I was wondering how and where do i screw the transmission vacuum line to?? On the original carb it screws into the base.....but on this new carb there isn't anywhere where it can screw into...Below is a picture of fitting on the line
ID:	41569   Click image for larger version
Berto504 is offline
post #2 of 6 (permalink) Old 07-04-2014, 10:03 AM
Quoted: 11 Post(s)
You can use one of the 2 manifold ports just in front of the holley, the PCV valve can connect to the other. Google "Edelbrock vacuum fitting" to find the parts you need.
05GTO is offline
post #3 of 6 (permalink) Old 07-04-2014, 05:04 PM Thread Starter
So you're saying I can connect the transmission vacuum line to the intake manifold?
Berto504 is offline
post #4 of 6 (permalink) Old 07-04-2014, 07:47 PM
Quoted: 11 Post(s)
Yes, the modulator needs manifold vacuum to operate properly.
05GTO is offline
post #5 of 6 (permalink) Old 07-04-2014, 08:06 PM Thread Starter
The line is metal and it won't reach
Berto504 is offline
post #6 of 6 (permalink) Old 07-04-2014, 08:09 PM Thread Starter
I want to make sure we are on the same page. That line goes to the carb or the intake?
Berto504 is offline
67 GTO /HO transmission cooling line pablogum 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 05-23-2014 08:22 PM
Will a 79 pontiac motor and transmission fit in 70 gto codywp 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 06-13-2013 12:49 PM
newby question - myserious vaccum line from gas tank GroundHog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 04-09-2010 08:15 PM
Line's Pontiac GTO holds onto No. 1 qualifying spot at Pomona 05GTO In the News 5 12-05-2005 09:41 PM
